Has anyone gone over 50,000 miles with no issues?
2019 just turned over 66,000 miles - no issues beyond normal maintenance stuff. I love this truck!
TJC
As for the cat degraded part, do you ever push the skinny pedal hard for a few seconds or more? If no, then you should try the good old "Italian tune up" procedure on a long E-way entrance ramp.
Basically get the exhaust gasses flowing hot and heavy in the cat to burn out any extra carbon that might have built up from using to light of pressure on the skinny pedal.
Additionally,
Use ONLY Top Tier Fuel, and maybe a can or two of TechRon. It will clean up any sticking injectors that may be running a tad rich which foul the cat over time (as does cheap gas).
If that doesn't help you can always try this stuff (I've never used it).
All of this is far less expensive than Cat replacement.
Dereku
Chicagoland Area
120k. Replaced rear brakes, they were glazed woops my fault. Trans at 75k. Plugs every 30k. Since 75k trans serviced every 30k. Diffs done every 50k. Ect. I over maintain but a blown trans is common for a long time ford truck owner. E4OD or 4r100 anyone lol.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Additionally,
A few years ago I used a similar product on my son's Mustang, Cat-A-Clean I think it was called, it did work, the CEL stayed off, mpg was better, and the smell went away.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
I'm still on my original brakes all around at 75k. Just passed inspection to boot.
My rears were replaced at state inspection only because the caliper sliders stuck and the inner pads were worn out. The outer pads were fine. This year's inspection is next month but I'm anticipating needing new fronts.
woodworker
Joel
virginia
2021 Ranger Sport
With 60+ years in maintenance, I firmly believe that how well you take care of the machine determines how well the machine takes care of you.
