FORScan Speedo Calibration for larger tires
No the free one works.
You will just need to get a new license after two months if you want to do more changes.
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Went to make some changes and couldn't because I didn't get the extended license. Haven't done it yet.
A little help here please...I've loaded Forscan program and received a trial extended license. But after following procedure,..connect cable to OBD and PC, ignition on, open app...everything seems to read and it recognize my my modules and vin but when I go to configure, it says I need extended license which is already installed?!:facepalm::headbang:
I'm not sure what to tell you other than making sure they key you got took correctly and it shows as registered/activated. Also make sure your hardware ID is correct when you generated the key.
j0shm1lls
Josh
SoCal, USA
www.youtube.com
This Thread is slightly outdated now so I just wanted to update it. Changing the size in the mm selection now does work!
Some fine tuning will still be required. I changed mine to the manufacturers specifications on the tire and instead of being about 5 mph slow on the speedometer I’m about 2 fast. Could be several different issues, how the tire sits on different size rims will effect how tall it is inflated. Other issues too so I’ll keep messing with it until it’s a little closer. I know 2mph isn’t a big deal but small stuff like that bothers me so I’ll tweek it.
Does changing tire size this way also generate a DTC without throwing a check engine light or does this get around the DTC issue that was caused by manually editing as-built data?
Flapilot
Jordan
Parrish FL
2019 XLT
I do still have the U0422 code
“invalid data received from Body Control Module”
no check engine light.
How do I check that it is registered/activated? Thanks...
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Emissions testing supplier
The screen where you got your hardware id. Once its activated properly it will read that you have an Extended license next to the hardware id.
It is the question mark icon in the lower left of the app. It should say "Extended license. Registered to: xxxxxxx. Valid until: xxxxxx
TKDMasterV
Pooler, GA
2019 Ford Ranger Supercrew XLT - Sport
Did mine yesterday. Same results. Used manufacture size spec then adjusted down until it was almost exact. Started at 2569 ended up at 2482. It works but got the U0422 code. So going back to original setting will get rid of the code?
Did you do the relearn PCM thing after? I did not.
I did Bambi mode and set the key fob panic at two presses after I was done with the tires.
Cape Cruiser
Bret
Southern Delaware
31 Ford-20 Ranger Lariat FX4- 19 Ranger Lariat 4x2
retired mechanic
Mike where you able to change the key fob panic to 2 presses? Thanks Bret
gfitzge2
Gregg
Louisville, Kentucky
Retired Electrician
Modify behavior of alarm button on fob
BCM 726-37-01 xxxx xxx2 xxxx Panic alarm on fob enabled
BCM 726-37-01 xxxx xxx1 xxxx Panic alarm on fob requires 2 presses
BCM 726-37-01 xxxx xxx0 xxxx Panic alarm on fob disabled
Thanks Mike,I guess I need to get forscan as I hate that panic alarm. Bret
I've had it on several vehicles now and I've not used it on purpose one time. There is an option to make it two presses or to disable it completely. I set it to two presses but still accidentally activated it once. I may end up totally disabling it.
Edit: Gregg, you beat me to it! :)
