FORScan Speedo Calibration for larger tires
hogsrear
Daniel
CT
2021 Ranger XL STX
Tried searching but haven't had much luck. Has anyone (non Forscan users) had luck getting the dealership to do this calibration? I am ready to swap for larger tires and want my speedo/odo readings to still be correct. To me this would make more sense than buying the scan tool, assuming it's something that would be really easy for them. But maybe not?
TKDMasterV
Pooler, GA
2019 Ford Ranger Supercrew XLT - Sport
I asked the dealer on two separate occasions, two separate service guys and was told both times they were no longer allowed to do it.
hogsrear
Daniel
CT
2021 Ranger XL STX
Strange. I guess it's still worth asking my local dealer, especially if I have them do the front shocks and putting on the larger tires anyways. Also saw someone above mention this (years ago now) but will gladly pay to rent someone's calibrator!
Mustangski
Nomad, everywhere
2021 Ford Ranger STX/FX4
US Military
Have a 2021 Ranger FX4, original tires were the Hankook ATM 265-60/R18's. Recently bought some Tremor take-off rims with the factory General Grabber ATX 265-70/R17 tires. I have forscan and started the process to get the speedo accurate, however when I checked cruise control against a speedo app on my Iphone 8 it was almost exact. Took several test drives from 3 to 30 miles at a shot and only averaging .03-.06 miles farther per mile on my speedo app versus the truck. Basically the MPH is exactly on until about 55-56 MPH, then only off by 1 MPH. Since the online tire calculator shows a 3.6% increase in circumference, I'd assume the factory speedo was a good bit off from the start. Honesly don't think I'll adjust it at all since its so close.
Anyone else notice this when they increased tire size?
THLONE
Thom
Tucson,AZ
internet wise guy
You are never going to get a perfectly accurate speedo reading at all speeds. The tires get larger the faster you go.
Mustangski
Nomad, everywhere
US Military
I get that there are several variables to gaining accuracy on speedometers, and not looking for perfection. I was just a bit surprised that the larger tires seem to have made the speedo more accurate. It wasn’t a large jump in size, I would recommend checking your speed with GPS before purchasing all of the stuff to use Forscan especially if you only plan to use it for tire circumference.
side note, I called local dealer as well. They will not adjust the speedometer, so it seems you’d have to use Forscan or purchase a tuner to adjust.
Reactions: EJH
Ronbo
Ron
FL, CT, TX
2019 Ford Ranger XLT FX4+
Can anyone with a Tremor and Forscan, who is running the Grabber ATX 265/70/17 tires, check what the mm setting is in the BdyCM module under “tire circumference “?
Cane777
Carlos
Puerto Rico
Ford Ranger 2022 4x4 xlt
Electrician
Anyone have the tire circumference for a 33x12.50r17 m/t? I am slow by 1/2 mile with 2490 in forscan.
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
Not sure how to fix it but here is what I found on the U0422 code.
SCCM U0422:00Invalid Data Received From Body Control Module: No Sub Type InformationThis DTC sets when SCCM recieves an invalid message from the BCM.
It looks like the value is also stored within the SCCM or maybe there are only a few default values allowed? Maybe there is a way to do an SCCM relearn or change the value in the SCCM to match? Not sure but thought this might help as I hadn't seen anyone mention the steering column control module with this code.
I will probably put larger tires on my truck some day so hoping maybe someone figures this out.
Reviving a Zombie Thread Here... ?‍♂
Had my neighbor come by today with his Forscan. We made the change to the BCM and got the error above. Looks like we need to adjust PCM and TCM too. Question is where and what setting do we need to get to to make the change or to force it to learn the new values?
EJH
Ed
Subarus, 2021 Ranger
Older thread, but I noticed the exact same. I went from 30.5" to 31.5" tires and at 50mph after the new tires, my speedo is 100% spot on. Kind of odd.
ive changed tires sizes twice with the programmer and had 3 different tire sizes. so far it seems like the speedometer in the 5g is most accurate at higher speed and is off at parking lot speeds.
i compared mine at parking lot speed, residential, and interstate speed. the gps, phone, and smart mirror are all within 1 mph of the dash so im happy with it.
Reactions: EJH
i would check the specs from the manufacturer. revs per mile. or kilometer.
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
late but forscan has this for changing tire size
https://forscan.org/forum/viewtopic.php?t=15994
Grandaccess
Robert
Binghamton, N.Y
2021 Ford Ranger XLT FX4
Computer Consultant
I have. Changed to the 285-70/17 setting. No codes thrown.
if you remember after 5 years LOL what is the MM for 285/70/17?
