FORSCAN HELP! I NEED ALL IDEAS!
Washingtonwarrior
Josh
Washington
2019 ford ranger lariat
Construction
So I did a kam reset after I had a tune on the truck and this popped up.
I can’tfigure out how to get rid of this and I need the experienced to just random ideas on how to fix this . Because I’ve taken it to the dealer and they can’t even fix it (they dumb) .
I made 4 changes on my truck before the tune in forscan
1. splash screen
2. Daytime.parking lights on at same time(for raptor grill)
3.intelligent off road display
4. Wheel circumference
I took all these back to stock settings and I stil get the check engine light code.
the dealer did put a new pcm module . Thinking that was the problem andthey still can’t figure it out. I get it back tomorrow and I’m trying to get ideas on. How to get rid of this .
truck runs great with this error code but it’s just a pain to see the check engine light.
many ideas please please please help! I’m running out of ideas .
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
Go in to DTC (Diagnostic Trouble Codes) section and reset the CEL (check engine light).
CO2Ranger
1. splash screen
Which tune and did you put the tune back on the new PCM?
Washingtonwarrior
Washingtonwarrior
Josh
Washington
Construction
Oz tune and no I haven’t put the tune back on yet . I’ve been talking to ken and I have to send him a new stock file to see if they updated the module . If so then I have to resubmit for tune update
puckdodger
Oshawa
Can you verify or edit the VIN is accurate?
Washingtonwarrior
Washingtonwarrior
Josh
Washington
Construction
So what is Forscan reporting that error to be? Got a code on it?
There are 2
0x7E8:p0630
0x7E8:U0422
ill have to look tomorrow what they actually say but it lines up with the pcm vin does not match bcm.
Washingtonwarrior
Washingtonwarrior
Josh
Washington
Construction
I was going to reload factory as built blocks In the pcm but they didn’t match and I didn’t want mess anything up .
CO2Ranger
Did you resolve this issue? What was the solution?
Washingtonwarrior
Washingtonwarrior
Josh
Washington
Construction
Issue resolved last week. They had to have a ford engineer remap the bum and update it .
LB'sTremor
Loren
Tampa
22 Iconic Lariat Tremor
IT
Normal see #4
https://forscan.org/forum/viewtopic.php?t=17208
Common issues:
(i) FORScan will show all blocks of data in the module. Not all of these blocks are configuration, some may be module internal data that are not a part of As-Built. It is not necessary to back it up, because module will create these data by itself.
(ii) Factory .AB file may not contain all the configuration blocks available in the vehicle. If the number of blocks in .AB file doesn’t match the number of blocks in the module, a warning message will appear. It is recommended to move forward and complete the writing.
