Ford App Location Service Updated App funk
FerdRanger
Ferdinand the Great
Central NY
2020 Ranger Lariat Sport 4x4
no thanks
seems they “updated” the formerly known as Fordpass app recently……..
Its been showing my truck parked several miles away when I know it’s in the driveway……
it did refresh once when I was parked with the truck idling for a couple of minutes….. but now it’s back to showing it parked on a road I went down a couple of days ago
anyone else spatially challenged?
I was hesitant to update mine and skipped the first one they had a couple weeks ago. I noticed a new one so I just updated mine 2 days ago and so far so good. 🤞 We were all over Tucson today at several different stores and it's showing mine here at the house now. This happened to me about a year ago before doing the last up update on the unit, not the app. It kept showing my truck parked back in AZ when we had moved to AR 4 months ago. 🤦‍♂️
You could try signing out of the app and then signing back in it to see if that helps. Or delete the app then reinstall it and maybe that'll fix it.
RangerBill
Look in the Sync menus for the modem serial number. If it is not displayed the modem is locked up. Many times, pulling fuse F9 for the telematics in the under-dash fuse box (BCM) will reset it.
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
I
thanks
I’ll try logging/updating again before deleting/ reinstalling …. but it’s happening on two different devices so might have to try pulling the fuse
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
thanks , appreciate this suggestion but I can remote start so isn’t that modem related?
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
pulling fuse didn’t work….
RangerBill
Do you see a serial number for the modem in the Sync screens or is it blank?
Another thing to try is to go in the Sync menus and do a hardware reset which resets everything to factory settings.
On the new Ford App:
On the Vehicle Location Map (Page)
Tap the (Circle) (Looks like a Roundabout Sign) in the upper RH Corner.
That's the Refresh Location (tab)
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
I didn’t do this yet but will
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
several times unsuccessfully
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
I’ll check the sync screen for the mode, but now i’m into battery saver mode…….
I planned on changing battery out soon, and perhaps the battery state of health has something to do with it
Does anyone know exactly what changed with this "update"? I don't use the app too often, but I did do this update and from what I can see, all they did was change how it looks - I don't see anything new - and they still haven't added the ability to add receipts to the service history (which it used to have).
It really annoys me when companies do this - they don't improve the software, they just make it "different". The only possible reason I can see for that is to justify the effort. But now I sound like a grumpy old man..... :LOL:
FerdRanger
FerdRanger
Ferdinand the Great
Central NY
no thanks
took Ferd for a ride to charge up the battery
modem was present in vehicle settings menu and now correctly shows location
the remote lock and start seem to happen quicker than before..
maybe just needed time after app update… who knows
I recall Ferd was parked at MAP for quite awhile after I brought it home
