Factory Keypad Failure
Monty
Prattville, Alabama
Honda
Unit worked when I picked up Truck. 5 days later keypad shows no LED activity nor will it open to code provided on the little card provided from Factory. Apt scheduled after initial look-see from Service Manager.
mrohshay
Christopher
2010 Ford Explorer Sportstrac
I had a defective keypad also. The dealer reordered one on a Warranty Claim. Mine wad dead on arrival and never worked.
Floyd
illinois
To what keypad are you referring?
Rick - Saber
NC
Sport Ranger 4x4
@Floyd I think they are talking about the optional external keypad on drivers side door to unlock the vehicle.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
@Monty @mrohshay If you guys happen to see the keypad out while messing around with this could I get some pics of the back side and the electrical connector?
Thanks...
Daniel
t4thfavor
Chance
So the dealership told my dad that they only have the stick on ones with the battery now, and that there is A. No "approved" battery replacement procedure, and B. No hardwired option available.
Maybe yours just has a dead battery?
Does anyone have a confirmed hardwired one installed on their truck?
VAMike
2019 Ranger Lariat SuperCab
I supposedly do, but I'm not going to rip it off to check :)
DakotaGuy
Black Hills, SD
2022 Ranger SuperCrew XLT Tremor
The ones they sell as an accessory look exactly like the ones installed at the factory. You sure the Ranger doesn't just use the battery ones?
VAMike
Nope, and I'm still not going to rip it off to find out. :crackup:
DakotaGuy
Black Hills, SD
People have looked and there is no wiring harness listed for a keypad so I think it's safe to assume they are all battery powered. No need to rip it off. Anyhow I wouldn't mind adding one to mine, but they appear to still be back ordered.
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
The only wiring the keypad would need is power. I sure hope it is wired and not battery operated. It is a factory installed option, and not a dealer installed option, so I wouldn't be so sure it's not wired to power.
DakotaGuy
Black Hills, SD
Actually on the Ranger it's not even considered an "option" but referred to as a factory "accessory" or dealer installed if you wish. I still think it's the same part either way, but I guess we won't know until the first door panel on a keypad equipped vehicle comes off.
t4thfavor
Chance
99% sure it’s battery powered...
earsmccoy
Matthew
Southern California
2019 Ranger Screw XLT FX4 Sport Package & 2016 F-150 Super Crew FX4
There is no separate door harness part number listed with or without door keypad. So unless there is a connector taped away somewhere in the door on all of the Rangers (with or without factory keypad) then it will be battery powered. At least not for 2019, perhaps 2020 will be different.
earsmccoy
Matthew
Southern California
Here are the part numbers and description just to clarify. There is no option on door wiring harness with or without keypad. It is 99.9% going to be battery powered.
0D2C0aGAhVIXsbBi5TntMuh-zU5pJ8Gz16655a7YAsAxcMsWPJuI7lL9qxXDES5F4Dz0pWEH1SakZ-2A_U6=w328-h222...webp
ZmNQGW6mEokmzKc8OiNPqRLdpvnpqBJB6wgeLeBwP-C1-1yE2fpT5IsnJjUWp2uRHxAlf0pLPV_1kWxj2OI=w301-h309...webp
