Engine cover install kit - what you get
sootie007
Clermont
2021 LT 4 x 4
Electronics
So I read guys were getting misfire codes if water gets into the spark plug holes. My 21 LX came with no engine cover. So I headed to ebay and bought one for $99 with included hardware from Rod Baker Fordstores.com ....heres what you get / do ....VERY basic but I figured a few may be interested. J
wanted33
Down south in Dixie
Mustang GT, Jeep Wrangler
Old used up LEO
Thanks for the info John. I been mulling over buying one in my mind. But, like an old woman I can't make up that worn out mind of mine. :)
sootie007
sootie007
Clermont
2021 LT 4 x 4
Electronics
Haha...ps engine sounds slightly quieter in cab.....
Don’t think I payed more than 50 bucks for mine. The hardware is also optional but helps. They’re asking way to much for some bolts and nuts that also come 4 to a pack when you order them. Still have 6 bolts in my tool box. Now I also added a badge to mine just to set it apart seeing it’s a collector’s item now!
Buddybiro
Buddy
2020 Ranger xlt
Can I ask how did you attach the oval? Is it staying on ok?
Sammy
Tenn
2024 Lariat FX4, 2019 Ranger... traded.
Get in touch with Benny at Levittownfordparts.com. He can get you and awesome deal! Will be able to save qute a bit. He's on Ranger5G.com.
I attached the oval by punching some strategically placed holes for the mounting bosses to go through then used a crap ton of hot glue and also filled the holes I punched before sticking it on. Has been on about a year now and still holding well. I was going to use the push nuts on the bosses from the back but have not needed to do so as it’s holding fine.
just an observation,
many people buy this cover for several reasons
one of which is to quiet down the noisy HPFP
as you see in the pics above, it doesn't even go over the pump, and the pump already has a feeble cover on it. its dB killing abilities would be very minimal at best.
why has no one made note of this before?
many people have bought a placebo and now likely tell themselves "gosh by darn it she sure is a quieter motor now" when its just a hat for the engine
BUT...it's sure to add several HP by "smoothing" the airflow over the top of the engine. All those peaks and valleys and hoses n stuff sticking up must trap air, thus slowing down the truck. :crackup::crackup::crackup:
Buddybiro
Buddy
2020 Ranger xlt
I glued a screw to the back of the oval and put it through the foam with a nut and washer on the back. It should never come out. I also used a silver sharpie on the eco boost letters. Thanks for the great idea.
DreamSports
Helendale CA
2022 Ford Ranger STX
Looks great.
NeilP
Neil
Spearfish, South Dakota
RETIRED!
Here's my finished install with 7-lobe hand nuts. They fit perfectly.
Where did you get the hand nuts? Looks like a worthwhile upgrade!
RangerTex
Pi
TX
2023 Ranger on order
Contractor
@NeilP,
Here's the source. I also used 1/16" thick x 1/2" diameter rubber washers under the hand nuts to keep them from loosening.
NeilP
Neil
RETIRED!
@NeilP,
Thank you for the information! I ordered a set.
RangerTex
Pi
TX
Contractor
@NeilP,
Did you get what you needed to complete your engine cover upgrade? Did it work out for you?
