Easy Auto Start / Stop eliminator
Mellow
DFW, TX
Reading the manual... if anything is plugged into the 110 outlet, Auto start/stop is disabled...
"Any of the following conditions may resultin an automatic restart of the engine:
•The blower fan speed is increased orthe climate control temperature is changed.
•An electrical accessory is turned on or plugged in."
So, I found a nightlight I had handy... plugged it in, and even with the nightlight off... auto start / stop was disabled... I think.
I'm thinking any 3-prong plug/block off item may be considered 'plugged in'... doesn't have to actually use any power...
I haven't tested it yet as I was just thinking about it while getting ready for work so hope this is right, apologies if it isn't the case.
Monty
Prattville, Alabama
Honda
Good job on your excellent discovery. Night light= 3 bucks. The other solution $89.95 plus labor time. Kudos bud!
Mellow
DFW, TX
I'm wondering if those cheap plastic child proof outlet plugs would work...will try later as I don't have any handy. Those would be low profile and allow closing the cover.
Mellow
DFW, TX
Looks like it works but whatever is plugged in has to be using some energy. Someone else mentioned they were using an old laptop and kept it plugged in and that's what got me thinking about the nightlight idea. I don't know if an LED nightlight draws enough current to trigger the system to not stop.
Rinn69
N. Central Iowa
Retired USAF MSgt
I just used a 2 to 3 prong adapter and it worked (the little A circled with a slash through it appeared)....I only started the engine in the garage, but will see how long it lasts later. Wish I had a child proof outlet cover....
Mellow
DFW, TX
Yeah, it works in the garage but when you actually drive it, it won't... needs some power usage, that was my experience.
Rinn69
N. Central Iowa
Retired USAF MSgt
Well, crap....back to the drawing board.
Mellow
DFW, TX
Mellow
DFW, TX
The things you creative guys will do to justify avoiding to hit an extra button on the console to shut it off every drive.
I don't mind hitting it every time but so far I can't get into that habit and with this cheap option, I don't have to.. so works for me... now, I'm cheap so anything over 10 bucks and I'm not gonna do it.. lol
Hollisterpat
Pat
Hollister, CA
2019 Ranger 2x2
Tried the AC option using iPhone charger and did disable the function as long as the phone was attached. Removing it resulted in default auto start/stop functionality
kieefer
keith
I had this simple usb charger that lights up when plugged in.
Fixed the auto-start function. :clap:
Any USB 110v charger will work if you don’t care for the lights.
