Driveshaft play
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
Mine has been doing it for awhile. I also had the whining driveshaft bearing but it stopped. I cannot be without my truck for the next 3 weeks at least so I'm just driving it. F' em I'm in warranty if the driveshaft falls out and I bought new so I wouldn't have to deal with stuff like this. :mad:
Kyp317
Tom
CAD Design/Automotive Prototyping
Same I bought new hoping to not have to worry about this stuff for a while. At least with the slip yoke it took. 45min-1hr visit for them to diagnose it. Told me fine too drive it & they “claim” it’ll only take a hour to swap the new driveshaft in later today. I don’t know if theres a difference but this will be the 1st Ranger they’ve seen with this issue but they so F-150’s every week for this slip yoke bump.
MountainGoat
Missouri
I am just pissed because I always had two used vehicles (or more) so I could fix one while driving the other. Very easy and convenient setup. Now I have one new truck and I have to get rides to the dealer or sit there for 2-3 hours for something I could do myself in less time. I was under the wrong impression that a new vehicle would be painless for at least 100K miles.
Kyp317
Tom
I know how you feel. I was terrified if they would have had to keep my truck. I have a hour drive each way to work, I live way out in a rural area on a farm so no Uber, Lyft etc. When I asked if they had loaners I’d needed he laughed. Said they use to have around 60 not they have 5 to loan out due to the vehicle shortage.
MountainGoat
Missouri
Same, out in the sticks. I'm not sure what I'd do if I could go back to 2020. I could get two decent beaters for $15k and save the other $15k I spent on the truck. I mean I like the truck but it needs to earn its keep.
FordRacing
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
Well today I crawled under my truck and did the grease thing...
Upon removing the driveshaft I found out the front clamp on the boot (Closest to the carrier bearing) wasn't even on tight..(come on Ford) I could spin it around the boot. and the boot had worked itself down just a touch. I order some of the XG-8 PTFE Teflon lube and smeared a bunch inside the yoke and on the splines of the driveshaft... On my tremor I dont have a u-joint so that took me the longest to get a part and back together. All together took me about 45 minutes..
well worth it as the PROBLEM IS SOLVED after taking it for a test drive.
Kyp317
Tom
I got my 21 tremor last July & it only started doing it a month ago or so. Wonder if mine was loose & grease worked it’s way out.
FordRacing
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
Why I posted that, maybe something to just check... I couldn't for the life of me figure out why after only 13000 miles it was happing now I know why.
Kyp317
Tom
I was just at the dealer to have the driveshaft replaced under the warranty & they got it up on the lift but the wrong drive shaft was sent so they have to figure how that happened & order another one lol. They didn’t say if it was sent for the wrong vehicle or if because of the tremor package if that’s a different length?? About right right for my luck
navsnipe
Rockland County, NY
The Tremor has a CV joint instead of a universal joint at the axle end of the driveshaft.
Kyp317
Tom
Thank you. I didn’t know that. So pretty much either the Ford dealer ordered the wrong one or the parts supplier shipped the one for the non-tremor ranger by accident?
FordRacing
FordRacing
Gordon
Buffalo
2021 Ranger Tremor
IT
The tremor doesn’t have a ujoint on the differential ( like navsnipe said)it‘s some kind of flex joint encase in a material like the carrier bearing. I’m not sure it a cv joint although I guess it could have a bearing encased in it. It‘s got 8 9mm bolts holding to the diff
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Did you just remove the 8 bolts on the CV and it separates? Or is there a trick to disconnecting at the axle?
AvalancheFX4
Joel
Los Angeles
2022 Avalanche grey Lariat Ranger w/ fx4 package
Keeping it real
So I've been feeling this bump slip very faintly lately and bit more pronounced when very hot and driving for a while. Truck has 1,800 miles! So I'm leaning towards doing this myself as I don't want to deal with the stealership. Are you jacking it up from the differential? Jack stands on the rear axle , is jacking up the front necessary? Has anyone been able to reuse the boot and clamps? Is everyone using a torque wrench on the bolts?
Kyp317
Tom
I go tomorrow for the 2nd attempt to have the dealer fix this. Maybe they actually ordered the right driveshaft this time but I’m not optimistic lol. Keeping my fingers crossed
