Anyone who has a Tom Woods Driveshaft Installed
oarsirhc
NJ, USA
2023 Ford Ranger Splash Jungle Edition Eruption Green
Hello! Up next on my upgrade list is to install a 1 piece Tom Woods driveshaft. I've searched around the forums a bit but couldn't find anyone that had a step by step guide or video for removing the old driveshaft then installing the new. Is there a guide or video someone can point me to? Can I do this with the truck on the ground or will it need to be on jack stands? Also, any tips or tricks to help installation go smooth? You guys have been a lifesaver when it came to installing my leveling kit, so I figured I'd ask about this too. Thanks!
Lateknightucd
Patrick
Grand Rapids, MI
2023 Ranger Lariat Jungle Edition
Medical Compliance
Following as this is on my list for the next month or so!
Lateknightucd
Patrick
Grand Rapids, MI
Medical Compliance
Thanks! And acceptable to do with the truck on the ground and wheel chocked/parking brake on?
Colo_Ranger
2021 Ford Ranger XLT FX4
Edit: You have to lift the rear to rotate the driveshaft.
Reason for edit: I had a moment... @TJC called me back to reality.
TJC
You can't turn the driveshaft with both of the back wheels on the ground. You can do the front with the back wheels on the ground, but the back end needs at least one wheel off the ground if you have an open diff (both if your locker is engaged). I had my truck on a lift just up off the ground.
Am I missing something?
Colo_Ranger
Nope, you're not missing anything. Apparently, I don't remember how I installed the driveshaft... I swear I didn't lift the truck but now that you said that, maybe I'm forgetting the steps... like how women forget how painful child birth is.
2021Ranger
Barry
NJ
2021 Ranger
You also have an aluminum adapter plate at least mine did.
Reactions: TJC
TJC
I forgot about that spacer! About 1/2" thick IIRC. The driveshaft is an easy swap. About as difficult as rear shocks.
Stevedbvik1
2022 Ranger Tremor XLT
Don’t forget the two bolts to drop the carrier bearing. Also make sure your differential has the four bolt flange. Tremors and some non Tremors that have had a driveshaft replaced under warranty have the 8 bolt Rzeppa joint that TW doesn’t offer a drive shaft for.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Transmission in neutral allows the motion you need to line it up. As long as one end rotates you can get it in fine. Chocks and parking brake are all you need.
TJC
It will only turn as far as the slop/play in the differential. Not a lot.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Not when you unbolt the driveshaft from the axle. Then you have freedom of movement. Rear end can stay on the ground as long as you can fit under the truck.
TJC
But to do that you need to turn the driveshaft (and the wheels) to get to the bolts!
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
I didn’t when I lubed the splines before winter. A ratchet and socket won’t fit but ratchet end wrenches do.
