Dreaded noisy fan
Jhbryaniv
2023 Ranger Tremor
Jhbryaniv
2023 Ranger Tremor
Start your truck through the app a few mins before you get in?
I never noticed any fan noise but I also don't get into a cold truck... I always start it a few minutes before I go out.
I wonder if an engine block heater would keep the engine "warm" and thus cut down on the noise OP is concerned about... Wonder what that would do to the electric bill though.
Motorpsychology
Prescott, WI
Vagabond
The fan has a centrifugal clutch on it that will run until its parts are up to a certain temperature, anywhere from a few seconds to close to a minute. A block heater would't do anything to appreciably warm the fan clutch.
Semi Trucks have the same thing only the fan clutch is usually pneumatic. The clutch uses air pressure to keep the fan off (default always on). After several hours with the engine off, most of the air in the clutch may bleed out and will roar until there is a strong enough air signal.
Good catch! Mine are missing too. Ordering them right now!
Edit: On the other hand,, maybe not. Can get two of them for less than $12. But everywhere I check wants another $10-$12 in shipping. I refuse on principle. Put the damn things in a padded envelope and mail it. Probably $4-5 total.
I wonder if Benny could get you a discount? @LevittownFordParts.com
And they came like this, I think in a skinny box:
Jhbryaniv
2023 Ranger Tremor
In my little mind I was thinking it would warm the block thus the engine would get to temp quicker... There are no fluids in the fan thus null.
Dr_Strangelove
Adam
Henderson, NV
'22 XLT Supercrew 4x4
Art, Design, Photo & Video
Amazing how something is “dreaded” in one man’s world and another doesn’t even notice it
By using the word "dread" I'm picturing the OP in his garage with his hand on the key in the ignition, just before twisting it, repeating to himself "It's just a noise... it's just a noise.... it's just a noise... it's just a noise.... it can't hurt you..... just start the truck......."
WingShot
Andrew
Denver, CO
2021 XLT, Tremor, Cactus Gray
Graphic Artist
I'm going to chalk this one up on the side of the ledger that has...tailgate too high, truck lists to the drivers side, weld splatter on the muffler, etc...
Jesus Christ, what some people have the time to worry about.
Friday yet?
‘23 Lariat Tremor, Focus ST
Thx!
My truck has the weather stripping. Just want to add the bumpers.
I'll end up doing it. Shipping is just a sore point to me at times... like when it doubles the cost of an item.
Jason B
2021 XL STX SE 4x2
machinist
Look at the video I posted. Definitely has fluid. And warm/hot engine will need more air blowing thru the radiator, make the fan spin faster.
The reason for the loud fan at start up is that all the fluid settles to the bottom, thus engaging the clutch. After a few minutes, the fluid is pumped back to the center of the clutch.
bsr956
Brian
Lenoir, NC
2020 Ranger XLT 4X4; 2013 Nissan Altima
You guys just made me go check ?, my 20 has weather stripping and bumpers. :like:
Thx!
Sure rub it in, I suppose you also have the hood struts! =p
LOL, that was the deletion that I really affected my perception of the Ranger being a truck. I guess my frame of reference was old pickups and the massive springs they had.
The hood prop, even though that's all I've ever had on any of my vehicles, just felt wrong to me for the Ranger. So I added the Red Line ones ... =)
Of course, after adding the engine cover, I can just knock twice on the hood and the mice will open it! =D
Jhbryaniv
2023 Ranger Tremor
my, I opened this thread and all the mice in my garage got excited with how nice and warm that engine compartment looks. They will be over later.
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
Can confirm that the MHU (Mouse Habitat Upgrade), or engine cover, does pretty much nothing for any engine noise. It's pretty small and lays flat above the engine with an inch or two of space to focus the sound out to the sides.
Now in my '22, I was missing the side weatherstripping and would suggest adding that along with the engine cover (if this was "decontented" from your '20). I can't really say that side weatherstripping makes any diff to the sound, but I'd think that has a greater effect than the cover (lol, one decibel decrease?).
Plus the weatherstripping is a whole lot cheaper than that cover! Side note, mine was also missing the hood bumpers and I added those at the same time and they were inexpensive.
Only sure fire thing I've found is to crank up the radio! =D
https://www.oemfordpart.com/oem-parts/ford-side-weather-strip-kb3z16a238b (2 needed)
https://www.oemfordpart.com/oem-parts/ford-bumper-eb3z16758a (2 needed)
I think the side seals main purpose is to help keep rain out.
On mine, that is missing said seals I'll occasionally see my relay block, battery, ect get droplets of water from heavier rains.
I used 1/4 closed cell foam seal on mine. :p
