Cooling Fan
Traneman
Jay
Rochester MN
2019 Ford Ranger STX 4x4
On my old Ranger, the fan did make this noise at first, but why did the have an electric fan as well on the old ones, where this new one don't have the electric fan?
t4thfavor
Chance
The old ones had an electric fan for the AC condenser when the truck was idling. This one has a viscous mechanical clutch with an electonic "lock in" so the fan works nice at high speed as well as low speed. It's something that I haven't seen before in another vehicle.
Traneman
Jay
Rochester MN
Yeah, i wonder why they did that as pretty much everything out there uses electric fans..
VAMike
2019 Ranger Lariat SuperCab
The mechanical fan is more efficient at high flow (like you need for a loaded truck). Electric fans are pretty much a requirement for most vehicles these days, which use a transverse mounted front wheel drive configuration, so a mechanical fan isn't really a practical option. (Because a mechanical fan would be pointed at the side of the car instead of the front.) In cases where a mechanical fan is an option, an electric might still be preferred if you don't need to move as large a volume of air; traditionally, the electric fan would have less of an impact on engine power. Clutch systems like the one in the ranger make the fan more efficient than systems where the fan always run at engine rpm--but it's a more complicated and expensive solution than an electric fan, and if you don't need the mechanical fan for peak cooling, it makes sense to just go with the electric.
Pennsylvania
2019 Ranger XLT Sport Supercrew and a 2019 Yamaha MT09
Anyone else notice the fan kick on if the truck is warm and you’re creeping through a parking lot? Seems like mine runs ALOT.
Mantis
Timothy
Raleigh, North Carolina
2020 Ford Ranger Lariat FX4, 2014 Ford Edge SEL
When I start moving from a stop and it comes on it reminds me of the old 1 ton international truck we had on the farm.
