double din radio swap out, everything works!
Langwilliams
Langley
Lorain, Ohio
does the ventilation work or do you just leave it on auto?
Langwilliams
Langley
Lorain, Ohio
I replaced the stock head unit on my Harley an lost the outside temp an oil pressure features.
wickedZ1
Ken
Pa
I was looking at different head units and went based off what was confirmed to fit and not fit at the time. I was wanting a excelon system with the maestro cables.
I'm pleased with my setup but I could have gotten all the bells and whistles you got had I just waited some.
all controls work both onscreen and dials.
Looks cool, can you make the vehicle on the vehicle info screen and backup camera look like a truck, or are you stuck with a sedan? Also is the D above the car showing you in drive? Can it show actual gear or just PRNDS?
On the climate screen can you select the different outlet vent locations like SYNC? Heated seats?
Nice clean looking install
speedczar
Jose
So CA
2019 Ford Ranger XLT FX4
Trucker
What are the part numbers for Maestro? I'm currently ordering parts ( amps, looking for a Sub, have Morel Maximo components to install { but I might buy something different }.
Krzydmnd
Pennsylvania
2019 ranger Xlt
it does have a Gauge display but I didn't set up my sensor yet. I'll try this this week and see if it works
Krzydmnd
Pennsylvania
2019 ranger Xlt
part numbers in Pic
Krzydmnd
Pennsylvania
2019 ranger Xlt
looks like sedan only.
looks like just PRNDS but I'll check that too! didn't even think about it.
heated seats, yes, vent control yes. the seats showed up in the display after I turned them on the first time.
Thanks
Porpoise Hork
Bret
Houston
IT
@Krzydmnd That's a very nice and clean setup, and impressed that everything works. I like it. ?
It's not something I would probably do since I have the B&O system, but seeing these pics there is one thing I may do..
Swap the head unit bezel out for the one installed in the XLT. Ford in their infinite wisdom put a glossy highly reflective trim bezel in the Lariat and at certain times of the day, it and the AC vent trim cause some really nasty glare. Oh it looks super nice and gives a really clean look to the interior, but I'd rather it have a frosted surface than blind me while I'm doing 70 MPH down the freeway...
VAMike
2019 Ranger Lariat SuperCab
Agree, the plastic chrome is the devil for reflections. I really don't understand why manufacturers think it's cool.
Porpoise Hork
Bret
Houston
IT
I have looked and so far haven't found anything. Sadly looking at the parts breakdown for it, its not just a trim bezel, but has the integrated hvac controls as well and run in the $600+ range. I might take it by a place that installs vinyl wraps and see if they have something the same color with a flat finish.
