Diode Dynamics SS3 Light Pod (Fog Light Replacement Kit Pre Order)
Status
Not open for further replies.
Pandamotorworks Troy
Troy
Omaha,NE
13 Focus ST, 19 Edge ST, 19 Ranger
themikeyan
LA, CA
19 Lariat FX4
Quick preview, finally got the pods installed, will get some off road shots the next few days
Grey Razor
Central Florida
2019 Ranger Lariat Sport • 2015 Audi S3 • 2006 Lancer Evolution IX MR • 2005 Lancer Evolution VIII MR
Learning Technology Designer
Those look great! What mount are you using?
themikeyan
LA, CA
19 Lariat FX4
Thanks, they're the mounts from fordrangerlifts.com, I got a pair second hand, but old recommend them if you can't make your own. Sdhq makes some, too, and look like they come out wider and sit a little lower.
Grey Razor
Central Florida
Thanks for the info! Looking forward to seeing the offroad shots. :thumbsup:
Todfoxx31
Tod
2019 Cherokee Trailhawk
I was going to follow Stage3’s video for the Baja Designs fog light install, but found it much easier to simply reach up under the bumper and remove the 4x screws holding the fog lights in place with a shallow GearWrench and a T-25 bit. There was plenty of room to swap them out without the need to remove the splash guard and bracket.
I know this post is old, but I’ve ordered the same lights and was wondering if you used any spacers? I have the same kit but no spacers.
Grey Razor
Central Florida
Hey Jason, I know this is a old post but did you have to use spacers?
I did not use any spacers myself. The bracket's pivot-point is slotted allowing you to push the light inward giving you some room for adjustment. I was able to aim the lights as needed by doing so. However, if you need greater angles of adjustment then spacers would be recommended.
Diode Dynamics fog pods do not have adjustments built in...I made the mistake not installing spacers (not included)...fogs were aimed too high to be of any use...went back in a second time with 1/8 nylon spacers on the bottom screws...perfectly aimed now...
Status
