TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 47
- Messages
- 4,166
- Reaction score
- 10,687
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
Yet another reason I moved to Valvoline Protect and Restore 5w30. The info below is straight from Valvoline website.Did the engine oil used have the correct ratings as called for in the owner's manual? The correct oil has additives to help prevent low speed detonations (Low-Speed Pre-Ignition) which is very destructive.
https://www.valvolineglobal.com/en-ksa/what-is-lspi/
Better suited to modern turbo/GDI engines. Restore & Protect is specifically formulated for turbocharged and direct-injection engines and includes LSPI protection, which is particularly important in small turbo GDI engines.
Much newer oil specification. The current Restore & Protect 5W-30 meets API SQ / ILSAC GF-7A.
Deposit control is a major advantage. GDI/turbo engines can be particularly sensitive to piston and ring deposits. Restore & Protect's Active Clean technology is designed to remove deposits over repeated oil-change intervals and prevent new buildup.
Valvoline Restore & Protect has 79% stronger anti-wear protection versus GF-6-qualified oil.
