KTM Hauler
- Thread starter
- #31
So this morning I called the SWDS, South West Dealer Services. I was able to get a technician to call me back. This is the company that installed the alarm. He said the normal procedure to remove the alarm was to remove the t-taps or unplug them, leaving the t-tap and some integrity of the original wire. I asked him how many and which wires were cut and he said 2...1 of which is the ignition/starter wire. He said the standard procedure for these wires is to use butt connectors. THIS is what I did not want to hear. I'm still waiting on a call back from Ford. If this has any affect on the warranty, as I assume it will, I will not settle on simply removing the t-taps and having those 2 wires connected with butt connectors. If I cut into the the original wiring while installing an alarm myself, this would certainly void any warranty related to any issue down the road involving this harness. I can't see how the dealer/3rd party installing it would be any different. Cutting wire is cutting wire.I'd expect them to simply unplug the spade lugs and remove their stuff, leaving behind the t-taps. At this point they're likely helping to maintain some integrity to the original harness wiring. I also wouldn't think they'd use high quality butt connectors if they do remove the t-tap. What are your expectations at this point?
My expectations? A complete, unadulterated wiring system in the state it was when it left the factory.
