emesel
- First Name
- Mark
- Joined
- Mar 8, 2022
- Threads
- 13
- Messages
- 106
- Reaction score
- 92
- Location
- New England
- Vehicle(s)
- 2019 Ranger
- Occupation
- Engineer
- Thread starter
- #1
I have a 2019 Lariat with a Victron Orion XS DC-DC charger to charge my trailer batteries. I initially connected the XS to the 7-pin charge wire, but although I have measured up to 20 amps on the charge wire, most of the time it's much less; maybe only a few amps (as many said it would be).
So, now I plan to run cables from the battery back to the rear bumper using Anderson connectors between truck and trailer. I know the positive connection goes directly to the battery and the negative to body/chassis ground. My question is, are the points shown in the attached photo correct for where to actually connect the cables? If anybody has photos of their connections, that would be helpful. I plan to use 6 gauge cable and limit charge to 20 - 25 amps.
Also, if you could share which Anderson connector you used, that would also be helpful. I'd like to use a bulkhead connector; seems like this would make for a simple, neat installation.
Thanks in advance, Mark
