Sparky
Sure -- There is much more information on this under the Forscan thread.
PowerPoint 1 second time (This will turn off power points after 1 second of turning off truck)
BCM 726-39-01 0001 0101 006A
Using the althorigram from the Forscan thread -- Hours have to be converted to minutes -- Minutes converted to seconds -- Then scroll down the chart to locate the HEX Key.
Here's the factory line item setting (75 minute timeout timer):
BCM 726-39-01 1194 0101 000E
For the Power Points to be active for 18 hours -- Here's the new line item code:
BCM 726-39-01 FD20 0101 0086
If one receives a Check Sum error -- Simply except it and move on writing the new code to the module. Personally I don't correct the Check Sum as the software does this automatically - That's why one gets the Check Sum error when writing a new line item change -- Just except it .. .. Unless your well versed in HEX.
Good Luck !!
Good Luck !!
