CVF catted downpipe
Superdannyboy
Superdannyboy
@Superdannyboy has a CEL from the catted version. I have seen other posts where it has happened for other folks. I think I remember reading that the middle insert is best for the CVF catted downpipe.
Yea I have the high flow cat and I've had the CEL for months. I have the defouler already set with the middle size restrictor I'm gonna see if I can put it on without removing the downpipe.
importfighter01
Metro Atlanta
2020 Ford Ranger XL SuperCab
Good call on middle insert if catted. Sorry getting a CEL with a cat as that’s supposed to be one of the benefits of catted vs catless.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Not that I know nothing from nothin but I'd figure a cat off a dual cat luxe production V8 4.7l or bigger with the bigger inlet/outlet and shielded/recessed O2 bung with measurably more flow could be quiet.
The increased noise I keep reading regarding what is currently available is kind of a turn off. I'm happy with my exhaust system note and don't want add a resonator back in.
Superdannyboy
Superdannyboy
Hey that sounds like a great idea. Honestly the sound has grown on me and has gotten a little deeper over time.
Superdannyboy
Superdannyboy
Just an update:
I ended up removing the downpipe to install the spacer and it was waaaaaay easier to remove than the first time. It was actually quick. Used the middle size restrictor and haven't had a CEL.
Edit: I actually used the least restrictive restrictor (biggest hole)
Racket
Here and There
Transient
Just an update:
Explain the restrictor? Is it for the O2 sensor or the diameter of the inlet/outlet? I would guess it 'restricts' something which is counter to the intent of a bigger diameter downpipe.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
O2 sensor
Racket
Here and There
Transient
Colson
Anaheim
2019 ranger
Ford mechanic
Just an update:
what spacer did you use and could u possibly drop a link, I'm looking at getting the cv fab catted downpipe but don't want a cel
Superdannyboy
Superdannyboy
Post #22
I used the middle restrictor that it comes with.
Edit: least restrictive
Superdannyboy
Superdannyboy
Update, got a CEL. This time it was saying that the computer doesn't like the ratio coming out of the exhaust. Went to switch to a different size restrictor and guess what. I had it mistaken. I used the highest flowing restrictor when I thought I used the middle one. I can clear the code and it doesn't show as often as before the spacer but it's a different code. The code was p0036 and gave the following issue, "heater circuit malfunction". I'll swap the restrictor to the middle one and see if it helps. I'm currently at 13 mpg but I did just switch to 35's. I do think it is causing more fuel consumption. I'll also wrap the downpipe in exhaust wrap because in the summer the under hood temps get high if I don't shut off the engine while idling.
Superdannyboy
Superdannyboy
That's the kind of thing that should be engineered into the product not an add on.
It's illegal to add that I would think. Just like you're not really supposed to put a spacer but you can buy it and do what you want with it.
Superspirit
earth
22 ranger
The heater circuit for the 02 sensor won't be affected by the spacer. You need to properly diagnose that code. You probably have a sensor failing. But it could be a bad connection somewhere.
