Crooked truck
ToddTheCanadian
Todd
Ontario Canada
2020 Ford Ranger FX4 Lariat
Software Engineer
I just got a 2020 Ranger (Lariat) a few weeks ago. I was looking at it the other day and it looked like it was a little crooked. I went and got a tape measure, and checked at the front wheel wells, and on level-ground with no load in the truck, there is a 5/8" difference between the passenger and driver side.
I checked the tire pressure on both front tires, and they are both exactly 31psi.
Other than the truck looking a little crooked, I don't really notice anything unusual while driving.
I also noted a little bit of uneven wear on the two front tires, with the outer part of the tire being more worn than other parts of the tire.
When I bought the truck, it came with a 10k km warranty, and I was thinking of bringing it back to the dealer to have them correct this problem, but I'm not sure if I'm overreacting.
What would you do?
Crow_of_judgement
William
20 ranger screw lariat
If I read correctly, the driver side is lower than the passenger side?
Sounds normal to me since the fuel tank is on the drivers side however I also have a 2020 lariat, I'll go measure it if I can locate my tape measure
ToddTheCanadian
ToddTheCanadian
Todd
Ontario Canada
Software Engineer
I
Thanks, I'd really appreciate that.
Hey Todd - trucks often have a 1/2” lean and the Ranger is no different. Some have it more than others - Ford even has shims to even it out as it leaves assembly.
Hopefully, that’s all this is. Unfortunately, once you notice it, you can’t unsee it. :confused:
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
NotBudule
XLT
Just start adding shelter dogs to the passenger side until it levels out , everybody wins !!! please post some pics of your new "Ranger Dogs" on the "where is your dog " thread ...
What would you do?
Mine is perfect...every gap and panel are parallel and and even...the left side of the bed is same height as the right...super quiet, never makes ticking noises under the hood...the FX4 shocks are the best thing Ford ever invented...I've never smelled gas in my oil either...don't look that up...
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Mine is perfect...every gap and panel are parallel and and even...the left side of the bed is same height as the right...super quiet never makes ticking noises under the hood...I've never smelled gas in my oil either...don't look that up...
Sniffing oil is like sniffing your behind, you may smell gas.:frown:
JoeDop1
Mojave Desert
2020 Ranger Lariat FX4 Crew Cab
Retired engineer
Mine is perfect...every gap and panel are parallel and and even...the left side of the bed is same height as the right...super quiet never makes ticking noises under the hood...the FX4 shocks are the best thing Ford ever invented...I've never smelled gas in my oil either...don't look that up...
you forgot to mention your transmission. smooth as silk since day one...
myothercarizahearse
Cleveland, Ohio
Unretired
... and the tailgate lowers at the proper speed from factory?
Day one begins again at 95K miles...pin that to your dash...
What would you do?
Hi Todd,
Get the alignment checked and fix the tire wear issue...then remeasure the truck. Is it lifted or leveled? Sort sounds like it might have been...
