Confused with what tire pressure
Packattack
Ford Ranger FX4 Lariat
live in Virginia and I have FX4 Ranger with Hankook Dynapro ATM 265/60R18 110T tires and confused about what tire pressure to go with. I received the Ranger from dealership with tire pressure reading 47 psi, but the door jamb says 30 psi and online I see it says 35 psi.
Pinecrestjim
Pinecrest, FL
There's another thread about shipping the trucks from the factory with high tire pressures. Dealers are supposed to reduce the pressure to what the door jamb states during the pre-delivery check. Your dealer (and a LOT of others) missed that step.
Strokerduster
2019 ranger XLT, 2019 Edge ST, 1946 CJ2a street rod, shop full of motoorcycles
Go with what the door sticker says..........
rangerdanger
SF Bay Area
I would follow the door jam. 47 PSI is way too high.
Do you have a tire pressure gauge to double check that the TPMS is accurate?
Packattack
Packattack
yes, I will definitely double check that 47 reading and than most likely deflate...thank you.
Desert_5G
Eric
Arizona
Tacoma
30 is recommended. but ive found 34 provides a nicer ride.
pannwfn
Mississippi
2005 fx4 level II
If your not hauling anything use door. Max pressure on tire is for max weight the tire can handle. Does this make more sense.
Jason L
Mount Pleasant, SC
2019 Ranger XLT 302A
My ride was a bit bumpy on way home. Checked tire pressure, and it was 47. Reduced to 30 will see what it rides like tomorrow.
chasvs
Tampa
Factory fills high so they don't get below recommended by the time they are delivered. to dealers. Dealer Prep is supposed to verify and adjust before delivery to the Customer!
pannwfn
Mississippi
2005 fx4 level II
Yeah mine was 45psi and no the dealer probably won't check it. Am running 34 now will try 30 tomorrow. Slime gauges at wally world work well and you should already have one anyway???
joeb427
Door tag says 35 and I run with 33. I like a bit softer ride.
That's strange...I have an FX4 and my door says 38o_O
SemperVee
Dar
Olympia WA
With the bumpy ride the PSI is the first thing I checked... Mine was at 31 on the Hankook 18 tires. Taller tires also mean harsher ride across the board. They look nicer but perform less comfortably transmitting shock
