Cold Air Intakes
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
It’s basically a private road and he was parked on the side where they always park with their flashers to wait for an opening at the loading dock. If you were to look and observe before calling me a dick you would notice the speed in the lower left corner and see that I indeed “GUNNED IT” to a whopping 25mph in a 30 while going around him with a full road’s width because he’s on the SHOULDER!
Not knowing the situation but calling me a fucking dick makes you not only a cock but an unobservant cock that jumps to conclusions at that. I’m sorry if my video offended you because I drove my truck on my road next to a parked tractor trailer….
Eh, fair you got me there.
importfighter01
Metro Atlanta
2020 Ford Ranger XL SuperCab
@Loweredon33s - Is the outlet on your inlet elbow 3in or 4in? And any issues with EVAP readiness monitors being good to go since I don’t believe your part uses a Venturi like the factory inlet does? Know from experience that those flow rate monitors on the EVAP high pressure lines can be finicky sometimes.
Thanks!
Loweredon33s
Baltimore
2021 Ranger
Performance person
Th
Thanks!
The outlet is 2.5” so as to connect to the stock turbo. The actual pipe is 3.5”. So it’s 3.5” until the last bit of the coupler going into the turbo. The ejector assembly is indeed a Venturi and has been tested on my own truck for over 4k miles and many months. While I cannot promise that the engine light will stay off on every truck I can tell you that I have had no problems with the ones I’ve installed so far. You are referring to a P04f0 code correct?
importfighter01
Metro Atlanta
Th
That’s great news! Yes unfortunately I am familiar with that code.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I developed a turbo inlet pipe for our trucks. It improves power and throttle response along with a lot of other benefits for modified trucks. The photo shows the stock one compared to my pipe
Do these fit on stock airboxes? I see yours attached to the Mishimoto or am I seeing this wrong? You said you have a UPR dual vac catch can, how are you plumbing the WOT port?
Loweredon33s
Baltimore
2021 Ranger
Performance person
m
y Upr can doesn’t connect like that, do you have an old version or something? My can has a tee fitting at the pcv connection on the turbo inlet pipe. Yes you can fit it to the stock intake but it requires a little squishing similar to fitting Roush and AFe.
Racket
Here and There
Transient
my Upr can doesn’t connect like that, do you have an old version or something? My can has a tee fitting at the pcv connection on the turbo inlet pipe. Yes you can fit it to the stock intake but it requires a little squishing similar to fitting Roush and AFe.
I have the second dual valve they sold on the second can they sold (so they told me). Curious about a T fitting.
https://www.ranger5g.com/forum/threads/upr-products-dual-valve-catch-can.7863/post-140016
Yea I'm considering y'all's product if I can make it work and have the less expensive ones you spoke of left when I have the money. Might be a few months after spending money on the turbo intercooler and global leaf springs. I treat my truck too much.
Loweredon33s
Baltimore
2021 Ranger
Performance person
It’s in the current instructions if you’re curious about it. You have time to decide if you’re interested because I don’t have anything left in stock.
Racket
Here and There
Transient
The instructions for your elbow? Is it on the website?
My wallet breathes a sigh of relief for now ?
Loweredon33s
Baltimore
2021 Ranger
Performance person
The instructions for the dual valve catch can that uses the tee fitting.
Racket
Here and There
Transient
I see they've improved the kit (on sale now!) with a 'clean side seperator' which looks pretty trick. If I ever upgrade the turbo inlet I suppose I'll ask them for the upgraded parts. I'll have to replace the elbow that I drilled a hole through as was originally required.
Loweredon33s
Baltimore
2021 Ranger
Performance person
Yup, that’s the kit I have. I slightly modified my CSS. I don’t know if it did anything but..
