Code P0446 EVAP System Check Engine Light
harringtondav
East Central Iowa
Sounds like a good find - the Green wire is the VREF - Signal Return circuit.
Yea, I kinda saw this coming. I mustered enough gumption to get my creeper and check the canister vent valve and cable. ....looking for mouse chewing. The cable sheath was damaged but as far as I could peel it back the green and other wire looked OK.
...still a bit stiff from the surgery, but I reckon by next spring I'll be able to properly dig into most future issues. As a member of the Church of DIY, I'd rather eat a bar of soap than pay someone for something I can figure out and fix.
rrwhitman
Maryland
2020 Ranger
Hi everyone,
Check engine light yesterday - code P0451. When the truck was still under warranty I had a check engine light (don't recall the code) and was told it was a hose associated with the fuel tank evaporation system and that the tank had to be emptied and dropped to fix. What are people's ideas on how to proceed with this myself? The purge valve near the engine seems trivial to replace and I've read that the fuel tank pressure sensor can be done without actually dropping the tank. Thoughts? Thanks!
p.s. I do perceive that the engine is not quite as smooth at idle as previously.
RangerBill
Hi everyone,
Here is info from the shop manual:
P0451 - EVAP System Pressure Sensor / Switch A Circuit Range / Performance
Description:
This DTC sets when a fuel tank pressure (FTP) sensor range (offset) concern is detected. The FTP sensor output is offset by greater than 1.7 inches of water or less than -1.7 inches of water.
Possible Causes:
  • FTP circuit intermittent open
  • FTP circuit intermittent short
  • FTP sensor intermittent open
  • FTP sensor intermittent short
  • Contaminated FTP sensor
  • Damaged FTP sensor
Diagnostic Aids:
With the FTP sensor at atmospheric pressure, the FTP PID normally indicates 0 inches of water. Remove the fuel filler cap or, for vehicles with a capless fuel filler pipe, install the supplemental refueling adaptor provided with the vehicle to open the capless fuel tank filler pipe. After installing the supplemental refueling adaptor or removing the fuel filler cap, wait one minute to allow the pressure in the fuel tank to equalize with the ambient air pressure before accessing the PID.
Fuel Tank Pressure Sensor and Tube
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. Remove the fuel tank.
    Refer to: Fuel Tank (310-01 Fuel Tank and Lines - 2.3L EcoBoost (201kW/273PS), Removal and Installation).
    • Disconnect the electrical connector.
    • Disconnect the quick connect couplings.
      Refer to: Quick Release Coupling (310-00 Fuel System - General Information - 2.3L EcoBoost (201kW/273PS), General Procedures).
    • Detach the clip and remove the fuel tank pressure sensor and tube.
Installation
  1. To install, reverse the removal procedure.
rrwhitman
Maryland
2020 Ranger
Thanks, Bill. I've read that you can lower the tank enough to do this and not totally remove it. Do you know if that is true? Also, the links on removing the fuel tank and the quick release fittings - can you expand on those links and post as well? Many thanks!
RangerBill
I don't know, it might be possible. I have heard that if the truck had undercoating applied, that the undercoating material will get sprayed into the sensor and clog it, causing the code.
Here
XLT
Description:
Possible Causes:
Diagnostic Aids:
Removal
NOTE:
Installation
Hey Bob, is there a strong case for why most/all of that (pump incl.) couldn’t have been designed to be mounted on the side of the tank, rather than the top?
RangerBill
I would guess that it is easier to seal the pump to the tank at the top. The pressure sensor would have to be in the air above the tank so no liquid would enter it, so again mounted at the top of the tank.
It may be possible to just lower the tank (enough) for access
But I would try the procedure above first, install the (truck supplied) funnel and read the FTP PID, with a scan tool - (check actual sensor reading) Key On - Engine Off
With the funnel installed - its looking for (Atmospheric) pressure
Near Zero Reading:
Range: 0.0 (-0.5 to +0.3) and around 2.65 Volts (2.62 to 2.68 volts)
P0451 is one of those codes that can be generated by many factors and its generic (out of normal range) Too High or Too Low (Pressure Reading)
I would start with what the FTP - Reading is and if normal, start checking Purge Valve, Vent Valve etc - or cycle the funnel in and out a few times as it may just be the (fill vent) may not have sealed properly.
The (Quick Release) coupling is just a locking collar that you pull up or squeeze
Another note - If I recall - the FTP sensor comes as an assembly (Tube Assembly)
Tank Ref:
Fuel Tank Press Sensor - Detailed
Note: The small hole on the housing - This is the Atmosphere Press (Ref) Port - check for blockage
Have you had (Undercoating) applied or been off roading (Mud)? this may be blocked
rrwhitman
Maryland
2020 Ranger
Great information - thanks. No undercoating or mud here, by the way. Can you elaborate on what kind of reasonably-priced code reader is necessary to see that level of detail? The one I have only displays the P-codes. Thanks!
RangerBill
The program Forscan run on a Windows computer with the proper adaptor.
https://forscan.org/home.html
In the meantime - if you clear the code, when does it show back up?
Immediately , Just after fill up , or when you get below 3/4 tank and long drive (over 10-Minutes)
or
At Engine Start - after the truck has sat for longer than 6 hours (cold soak)
I would try - cycling the funnel or gas pump nozzle - through the fill inlet and see if the code stays away.
Another - Will your code reader - Read IM Readiness Tests?
You are looking for - is the self test running and failing - Not Run - P0451
Another is - if the tools has it - Look at Freeze Frame Data, this will tell you the conditions when the code set.
We are looking for - is it setting @ Key On (Rationality Check) or is this setting during the EVAP Monitor Test
Jason B
2021 XL STX SE 4x2
machinist
I remember on my old trucks, it was easier to take the bed off than trying to drop the tank. Don't know how hard that is on newer trucks.
Approximately 50% of the tank is under the cab , now you may be able to reach into the space and get to the (vent tube) but its a (NO) for the pump R&R as its under the cab
rrwhitman
Maryland
2020 Ranger
Airline Tech,
Using FORScan it looks like the Fuel Tank Pressure sensor is putting out a constant 2.08 volts. It was putting out 2.08v before inserting the funnel to open the tank to atmospheric pressure and it did not change at all after doing so. Based on your information that 2.65 volts was expected (and the fact that it is not changing) would you suspect the sensor has failed?
Regarding when the code was set, after I cleared it it remained off for a day while using the truck. The next day it displayed the check engine light again at start-up.
If you have any advice for further testing using FORScan, I will do that. Thanks for all of your expertise!
