Can I tow this with my 2019 Ranger
Bobh
Bobby
Indiana
2019 Ranger FX4
I am considering buying Apex Ultra Light 215BRK. The travel trailer weight is 4363 lb the length is 25' 4" . If I understand correctly the truck gross weight is 12,500 lbs. the truck+Cargo+people+trailer has to be under 12,500. Like here your input. thanks
Share
Randy
Randy
Ranger 2019
Share
Maximum Conventional Towing Capabilities
SuperCab
Drive Type
4x2 (Pick Up Box Delete)
4x2
4x4
Engine with Automatic Transmission
2.3L EcoBoost® I-4
2.3L EcoBoost® I-4
2.3L EcoBoost® I-4
Wheelbase
126.8 in.
126.8 in.
126.8 in.
Axle Ratio
3.73
3.73
3.73
GCWR
12,500 lbs.
12,150 lbs.
12,400 lbs.
Maximum Conventional Towing Capabilities 7,500 lbs.
7,500 lbs.
7,500 lbs.
SuperCrew®
Drive Type 4x2
4x4
2.3L EcoBoost® I-4
2.3L EcoBoost® I-4
Wheelbase
126.8 in.
126.8 in.
Axle Ratio
3.73
3.73
GCWR
12,250 lbs.
12,500 lbs.
7,500 lbs.
Snorebaby
Augusta, GA
SuperCab
Drive Type
4x2
4x4
2.3L EcoBoost® I-4
2.3L EcoBoost® I-4
2.3L EcoBoost® I-4
Wheelbase
126.8 in.
126.8 in.
126.8 in.
Axle Ratio
3.73
3.73
3.73
GCWR
12,500 lbs.
12,150 lbs.
12,400 lbs.
7,500 lbs.
7,500 lbs.
SuperCrew®
Drive Type 4x2
4x4
2.3L EcoBoost® I-4
2.3L EcoBoost® I-4
Wheelbase
126.8 in.
126.8 in.
Axle Ratio
3.73
3.73
GCWR
12,250 lbs.
12,500 lbs.
7,500 lbs.
With the chart above.....you have 3137 lbs to go to max out.
Bobh
Bobby
Indiana
2019 Ranger FX4
I was wondering if the length would be considered safe. I do plan on using a brake controller and sway bar. I am new to this process. thank you for your help
JeffM
Houston TX
2019 Ranger XLT
That should be no problem at all.
Rviator
FLA
retired aerospace engineer
What is the GVWR of that trailer? Probably closer to 6000 lbs., which is still below the 7500 lb tow rating of the Ranger. Does that 4363 lbs of the trailer include the options, such as a/c maybe a generator? You need to be aware of the loaded trailer weight.
2.7EcoBoost
NY
2019 Ranger FX4 Screw
Share
I am towing a Sportsmen 271 BHLE, it is listed as 31'3" @ 5,290 dry, so maybe 5,800lbs loaded, propane, bikes etc ( I don't fill my water until I get there). I have a Redarc brake controller and I use the E2 weight distribution with friction sway control. Tows like a champ. I am honestly blown away by how easily the truck pulls it and how steady it is. Watch some videos about how to set up your weight distribution correctly. It requires measurements of truck and trailer alone, hooked up with and without distribution. Don't assume the travel trailer dealer is setting it up properly. When I bought my trailer I still had my F-150 and that thing swayed terrible above 50 mph until I made adjustments. The Ranger feels just as stable as my F-150 did with both set up correctly. The 2.3 doesn't pull as effortlessly as the 2.7, but it really impresses me non the less.
Share
Hi Bobby,
I in most instances refrain from commenting on posts such as this but hate to see folks head into the unknown. You have a couple key metrics. Trailer tow weight rating, but also important is the GCW, Gross Combined Weight which includes that loaded truck ready to tow with all the gear and the trailer stocked and loaded with all the stuff you need. You really need to take this combo to the local truck scales to be weighed. Weigh the whole truck/trailer. Then weigh the trailer by itself. You will clearly be able to tell if you have overloaded either the truck or the trailer per the Ford Owners Manual or the trailers specifications... If you exceed GCW, then you need to decide what to leave behind. While at the scales, if overweight, start dropping items off to the side and reweighing. You will get an exact answer on where you are. So many folks assume and then find their assumption was incorrect as they sit on the side of the road with dire results like bent trailer axles for example... Take away is to weigh and understand...do not guess.
The Long Ranger
Gum Swamp Ga.
19 Ranger Supercab XLT 302a 18" PVD Chrome pkg., 15 Focus SE, 65 Falcon Futura Hardtop, 56 Chevy 3100 Shortbed, 05 Pontiac Vibe (700,000 miles), 93 Nissan King Cab, 05 Sebring Limited convertible (Joyride), 17 American Landmaster 450E, wife has some kind of Cadillac
HotShot ......no, really
One of my customers, a Toyota parts manager, told me he saw a Ranger towing a full size John Deere farm tractor!:frown:
JMM_AZ
Gilbert, AZ
2019 Ford Ranger Crew Cab 4x4 Lariat
Share
I've towed a 5500 travel trailer over 10000 miles without any incidents
Michael Bailey
Michael
Jemez Springs, NM, USA
2019 Ranger Lariat 4x4, 2017 Escape SE 2.0 4x4, 1974 Norton Commando 850, 1967 Norton P11 750
Trout Fisher, Layabout, US Army SGM (Ret)
You guys towing those huge trailers, what kind of mpg are you getting?
JMM_AZ
Gilbert, AZ
Averaged 8, AZ to Wy. 13 WY to Oh. 10.8 Overall. At an average of 70 mph. (2019 Lariat, Rouse cold air intake, Ford Performance (Borla) exhaust.
Garnet
Garnet
Moose Jaw, Sask.
Thats pretty good mileage. Better than i get with my 2016 king ranch with ecoboost. Havent towed with my rnager yet.
