Can I get some takes on this? (Badlands tires+wheels)
SilverSlugger
Wally
AZ
2019 Ford Ranger Lariat FX4
Baking
A friend is moving up to 35's on his Bronco. They have 5 take-off Badland 285 70 17 wheels and tires, the silver ones. He's going to give me a nice deal so if these can work id be happy.
Is replacing TPMS sensors a big deal? Ill have to replace all 4 on this set if i do this?
Is the lug pattern the same? Im 90% sure it is.
With the FOX 2.0 level do we think Ill have to cut fenders or replace crash bars with it being only 32.7 "?
Has anyone seen any Rangers with this look?
Im not 100% sure Ill do this but im open to hear any thoughts
They're the same offset and lug pattern as our Rangers so you won't have any problems. You might just have to loosen and adjust the crash bars in and they should fit. Otherwise just take them off. :shock::lipssealed:
CO2Ranger
Yes you'll have to replace or remove crash bars.
SDXLT
Josh
San Diego
2021 XLT FX4
I thought 285’s would rub the knuckle on the 17x8 +55 offset. I recall seeing others use spacers or move to a 30 or 0 offset to avoid rub with the extra width.
CO2Ranger
They won't rub the knuckle, it's close, but the tire won't flatten at the top so it should be fine. Never rubbed there for me, but sounded like it was rubbing the inner fender lining at full lock. Even with aftermarket crash bars you'd want to avoid full lock.
As long as the wheels are the same offset as the factory you should be fine. When I ran my 33s on my Ranger with the old man emu lift all I had to do was remove the plastic cover off the front crash bars and a loosen and push them forward. After that it was fine. I say go for it
You might have to max out your FOX coilovers or remove/replace/adjust crash bars bars, but it’s not like it’s major surgery to get it done.
I had 32.2” on +15mm offset and didn’t rub with 2.5” level - angled bars like @Frenchy above and was fine. I think there’s room to play.
Fingers crossed. ?
Would be the same as mine except with Bronco wheels...same pattern...
Alpinist
Scott
Seattle, WA
2019 Ranger XLT Sport
I have a set of Badlands 33's on mine, also with the Fox 2.0 kit. They mostly fit. Little rubbing on the inner fender/framerail. Looks like they should have come with these from the factory.
