Calling out Frenchy and his Variable Voltage Post
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
That particular Jump Starter you have, like any Jump Starter should have the Ground hooked up to the Chassis on Modern Vehicles if trying to Jump Start a Vehicle. That said I also understand that sometimes is not possible for the fact some dont have long enough cables and sometimes the Battery is so dead that you have to go directly to the Battery for Jump Starting.
As for Charging the Jump Pack, Clearly it lets you go of the Cigarette Lighter or a USB depending on what is available
You can charge it by Cig. or USB but it takes a lot longer per the review I saw. It takes about 2min when I connect it to my battery with the engine on. It is the last ~10% that takes the longest of that 2min.
Yeah, not recommended in my books. Check with the Manufacturer of the Jump Pack. Even with the NOCO Jump Pack I have, I just let it charge VIA USB and it does just fine
ctechbob
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
Do they mention that you can just let it be plugged in all the time? Seems like that would be the easiest way. Shove it under the back seat and leave it plugged in. Ready to go when needed.
Dgc333
21 Ranger Lariat
Well, that and your bodies resistance is so high that 12v isn't going to flow very much through you. it does, but we're talking tiny tiny amounts of current.
FWIW, I used to do product safety certification (think UL) for Motorola. All the product safety standards around the world consider 60 vDC (42.4 vAC) to be the upper limit as the safe limit for human contact. I wouldn't want to get my hands across 60v if they are wet but certainly no issue if they are dry.
Doc
Doc
Live oak fla
Howdy, pardner. The sure is a hot topic. What would ac/dc say about this. High voltage rock and roll im sure. Well, im from texas and dont ignore anyone here. The entertainment is free.
I just got nothing to say bad about anyone. Cept for hitler, or putin, or stalin, or something like that
TJC
Quite possible. I'm not tearing mine apart to find out.
Although, there wouldn't ever be heavy current going through there, or shouldn't be, at least not on a constant basis.
Good point though. My 500 amp shunt in my trailer certainly isn't small.
That is a lot of heat that would need to be dissipated if it was inline (series) instead of a Hall effect sensor.
I use Hall Effect Sensors (with voltmeter feeds) on my Home Main Electrical Panel when I'm running my back up generator to balance the load of the 220v Feed. This helps me keep my load on my inverter generator balanced and healthy. The wires are minuscule and the info supplied is great. The displays are located just above my breaker box allowing me to simply turn on/off circuits until I see a balance or I'm below the max wattage threshold. Keeps me from running outdoors then back to the panel box multiple times. Here is an excerpt page explaining how to use the two meters from the manual that I created for my wife.
I suspect the BMS sensor in our Rangers is collecting the same data plus temperature.
TJC
Don't forget to include our home grown crew of misfits in that category! :LOL:
After rereading your statement, the rest of the scoundrels could fit into the "or something like that" category.
TJC
Capacitors charge in a non linear rate to infinity... theoretically speaking.
Cabose-1
Eli
Student
Man @TJC , i have been bashed plenty by the people on here for stupid ideas. But take it all with a grain of salt.
Help when i can, take advice that pertains too me and contribute with awesome ranger stuff when i can.
And as always!!
GEN-Y HITCH
For proper towing. They make running boards now too!! But not for the ranger yet ?
2022 xlt fx2
TJC
And as always!!
GEN-Y HITCH
2022 xlt fx2
Not meant as a bash. I am extremely sorry if it came across that way. My sense of humor is a little off kilter from most.
I tend to paint all politicians with the same brush. Walks like a duck, quacks like a duck, it's a duck!
Sorry again for the miscommunication.
While most/many threads always veer off topic.....Let's try and stay somewhat on topic.:wink:
