Boomba Racing 2.3 Ecoboost Intake Manifold Spacer Now Available!
Status
Not open for further replies.
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
Increasing port volume without losing velocity is a good thing, I think the spacer should work as expected.
I would like to know what people think after they install it!
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Here’s the dyno for a stock 2016 EB Mustang with the TB spacer and intake manifold spacer. Dyno numbers look correct for a stock 2.3L EB too given that is a Mustang Dyno which is 12% lower than a Dynojet.
Looks like it allows peak hp to be achieved and maintained 1k earlier in the powerband, which is impressive. Ok @Boomba Racing when you have a TB and Manifold spacer combo ready to go like you do for other vehicles, I give you permission to take my money…
Sources:
https://www.boombaracing.com/ford-eb-throttle-body-spacer/
I'd want to see a tune on top of that.
Hi Mike,
Be data driven, where are the Ranger 2.3 L before and after curves for HP and Torque... Not that is suppositoryly going to work... No performance data on a Ranger 2.3L, I recommend sitting on the sidelines...
Fitzmotor
Gold Sponsor
Saugus
Hi Mike,
Good point, now that I think about it the 2.3L in the Ranger should be somewhat different than the 2.3L in the Mustang and the Focus, cams, compression maybe even port configuration.
It really is about hemholtz resonance, which I really only know enough about to know what it is.
I was basing it upon my experience with different engine, the 2.65L Honda V8 had a complicated barrel valve system that was capable of altering port volume, worked well, only saw minor differences on the dyno (midrange Tq) but the drivers really liked it, it smoothed out the dyno graph trace, which the graph above also kinda shows, an engine is happy when the Tq and Hp traces are smooth, hopefully it will be the same on a Ranger.
Well hopefully somebody here will jump in and do the install on a Ranger!
Living The Dream
I'm on the sidelines as well until more concrete info is presented.
In the Nissan Frontier world, the IMS moved the torque curve to earlier in the rpm range which made the truck feel peppier.
The Ranger has no lack of low rpm torque (well, no lack after the turbo is spooled anyway) so I'm interested in how it will respond to this.
Blmpkn
Maine
2010 ranger
2.6 honda v8? Do tell more
dondonbabyraptor
Brandon
San Diego
2020 Ford Ranger Lariat
I/O Psych MSc student
Call me a lover of trying snake oil, but my butt dyno and poorly managed data should give me enough to tell all y’all. I will let you all know what comes of these two upgrades once I can get the TB spacer. The manifold is here already, just don’t want to get inside the truck until both is here.
Fitzmotor
Gold Sponsor
Saugus
Yeah, it was during the C.A.R.T era, 2.65L single turbo V8, 17,400 RPM, at it's peak development it made 900 Hp.
It was a engineering masterpiece, one of which was the TU2 variable intake runner volume, as well as other ridiculously expensive stuff, only good for 600 miles, everything got changed except gears and cams, crank was good for 2 runs though, the qualifying engines were only good for 140 miles.
This was when the budget was 80m a year and the motto was "just win" now the engines have to go many many miles or the teams get a penalty.
That engine was $600,000 if the team damaged it, the current Indy engine is only about $100,000, the bean counters and the racing series have really changed things.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Never do 2 mods at once. How would you tell which actually worked or not?
dondonbabyraptor
Brandon
San Diego
Very true. I am just lazy. Gotta find someone less lazy for that data :p
Just be aware that a throttle body spacer usually doesnt make enough difference by itself. Why you ask? For starters even though you get more volume for the intake it is a very small amount. Also many people(myself included) have done dyno testing(I was in tech school doing this) and at best would maybe show a 1 HP gain(not really worth it if you think about it). Think about the amount of money spent to gain so little. Not really worth it at that point.
Now as for the manifold spacer you would have the ability to get a better change since the runners would be lengthened. If memory serves me right(@P. A. Schilke help me out here) a longer runner length is better for low end power vs a shorter runn is better for high end power. With that said you do have a probable theoretical chance that it wpuld make a difference. Worth the money? In my opinion not so much but if you wish to spend your money on it then go ahead.
Hi Chris,
My take is to see before and after dyno curves for the 2.3 L as I have not direct experience with these changes due to a lack of a sensitive study of the engine air flow. There have been instances where slight changed in porting have had very good results and in other cases...no real gain. So this is why I said to be data driven and sit on the sidelines until data is available for the Ranger Motor... Otherwise, spend your money and take your chances. CFD analysis might show the improvement in air flow if modeled correctly but I think Boomba needs to generate Ranger data, not Focus data. JMO.
RCMUSTANG
Ray
Los Angeles
This is generally the case.
Boomba Racing
Boomba Racing
Boomba Racing
Wood Dale, IL
2019 Ranger Lariat as well as many other vehicles.
Making Car Parts!
Status
