Blown transmission 2019…
Wang.S
Wang
Canada
2019 5G
Tech
maybe they have so many complaints they had to hire an additional 100 people to answer phones.
This is Ford. Say your statement over again...slower this time.
It was only a year ago Ford dumped over 3000 employees from the roster.
Prunecandy
Prunecandy
Brandon
Costa Mesa CA
2019 Ranger FX4 Lariat
Geologist
Got a call from them this morning but was in a meeting. I have been trying to get back to them but no luck. Let the fun begin…..
Yinzcity
W
Detroit, MI
I want to know where they're getting that $7000 number from.
IDK if there is new programming that has to go into a new out-of-the-box trans, I'd assume there is, but for a $3000 difference, I'd buy the trans and bolt it in myself and tow it to the dealer to program. The 4wd trans is actually $50 cheaper than the 2wd version below.
Even better, used low mileage units are going for $1500 around me. It may not have the latest parts, but for the same price as new, you could get four transmissions and the beer needed to put them all in yourself.
The programming is the piece that would have me worried a bit. The service manual says to reprogram the truck with the new valve body data for that transmission. I suppose it's possible for the 2 units to be off enough for the new one to not adapt correctly, but I would think the computer would figure it out.
I think it’s more about the BCM and options you have that match your VIN. So that’s the only programming I see with the adaptive taking over after that and going through it’s exercises.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Those used units are going to have the same defective CDF drum so who knows how soon you'd be repeating that.
Yinzcity
W
Detroit, MI
True, but not every one seems to fail, so there's always the chance the replacement holds. Or at least it holds for another 50k-100k and enough time to trade up to something better.
Zvedza
'21 Ranger Tremor, '04 SVT Lightning, '16 ZX-10R
wonder if the flushes arent helping.
GM has put out this notice for their 10spds, pretty sure its not that much different from ours
https://static.nhtsa.gov/odi/tsbs/2020/MC-10173416-9999.pdf
"The use of external transmission fluid exchange or flush machines is not recommended for the automatic or manual transmission. Use of external machines to replace the fluid may affect the operation or durability of the transmission. Transmission fluid should only be replaced by draining and refilling following procedures in Service Information (SI). Refer to Automatic/Manual Transmission Fluid and Filter Replacement."
Prunecandy
Prunecandy
Brandon
Costa Mesa CA
Geologist
Another day another boring update. My corporate advisor took the day off so no updates. Called the dealer to see if they were contacted yesterday and they have not. Thinking about getting a quote from a local independent shop just in case. Lucky for me my dad has a gmc canyon he doesn’t use so I’m using that for the time being.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
It has something to do with the solenoid pack and matching it with the car.
Transmission shift solenoid characteristic strategy, I believe that's what it is called.
This makes sense. I gleaned some information from reading through the GM 8-speed lawsuit that can explain it a little better.
When GM was engineering the 8-speed, they would just build the valve body, slap it in the transmission and let the TCM figure out the rest.
In the documents, they mention that other manufacturers with the same sort of complicated transmissions were doing 'wet tests' on every single valve body/solenoid pack they produced and including that calibration with that particular valve body/tcm. With the 'Gen 2' GM 8 Speed they are doing the 'wet test' to every unit.
This is likely what is happening in the 10R80/10L80's as well. Every valve body/solenoid pack is tested and characterized and that calibration has to be updated in the PCM as well when the new trans is installed.
jeff81
Connecticut
2021 Ranger Tremor
First I am really sorry you’re going through this. I hope you get it resolved and it doesn’t cost to much. It’s really a shame modern autos with 7-10 speeds are all junk.
To everyone upset with their good transmission saying they’re going to run from the ranger because of this problem I have to ask, where are you going? Every trucks with these multi speeds have issued. GM’s 8 speed is way worse than the ford 10 speed. Ram has the ZF8 which is slightly better but still has issues. The ZF9 is a toilet and also has many class actions. Toyotas has problems. Maybe the new Nissan? Haven’t heard a lot yet. But there’s a pattern. All the new transmissions seem to struggle. They’re never going back to 4 or 5 speeds though because they’d never pass fuel economy standards.
I dumped a canyon with transmission issues for my ranger and it’s night and day better in all aspects. I accept it’s not bulletproof.
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
Nissans 9 speed has shifting issues and failed valve body problems as well. I did some research to see if I was gonna keep the Ranger or jump. They all suck... at least this truck has a solid engine, better than most mpg, and quicker... I'm sort of cheating on that last bit... but hard to beat it for the price. Also throw in some interest rate shenanigans... and I've ordered tires and plan on keeping it at least two more years. Maybe a 6g later if that drum update proves to solve some issues.
i hate to agree with this but i feel like its true. i expect my transmission to give up any mile, already had some issues with it. with no manual transmissions in a truck we are stuck. well i think the taco may offer a manual but i have not seen one in over a decade with a manual. so it is likely a unicorn that no dealer stocks. the jeep santa cruz (gladiator) offers one but its jeep so its reliability is low and cost is six kidneys now that all the trophy wives, high school cheerleaders and express for men types are out trying to man up. I like the frontier but no manual and its still pretty new so i would not trust it for a model year or two.
jeff81
Connecticut
2021 Ranger Tremor
i hate to agree with this but i feel like its true. i expect my transmission to give up any mile, already had some issues with it. with no manual transmissions on the in a truck we are stuck. well i think the taco may offer a manual but i have not seen on in over a decade so it is likely a unicorn that no dealer stocks. the jeep santa cruz (gladiator) offers one but its jeep so its reliability is low and cost is six kidneys now that all the trophy wifes, high school cheerleaders and express for men types are out trying to man up. I like the frontier but no manual and its still pretty new so i would not trust it for a model year or two.
Taco are the worst. Even the new ones feel 10 years behind. I can’t understand their popularity. I travel for work so I’ve rented a few new ones and just not great. Nissan is Nissan. I just don’t trust them. And now they’re teamed up with Renault and just no. I had a Jeep. It was a bad time. Went to the diesel Canyon Denali after that. It was a worse time. GM f’ed me in the early 2000’s and I swore never again. All my friends said so much better now. Well no. 35000 and shot transmission and diesel issues. Before the Jeep id owned an older expedition and an 05 f250 I bought in 2010. Both I loved and couldn’t kill. Decide it was time to go back to ford and got the ranger. Even if fords are a little more ugly and all have that damn ford smell they just make a decent vehicle. Perfect no but decent and better than all the others I regularly drive as rentals.
I really enjoy my temor lariat. The seat is a little short. Doesn’t go back far enough. No cooled seats. LED everything but incandescent side market and tail lights. Why? Just a few marks missed. Why I got a canyon to begin with. But ya know it runs. Has damn good power. Looks great after a made a few mods. Can’t fix the seat but I’ve gotten used to it. Sound system is great. All in all I really like the truck for what it is.
