Bilstien 5100 finally installed
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Did the fronts today, only took 98k miles. Took me about 2 hours with the crappiest autozone spring compressor I ever rented. These springs are so soft it compressed with minimal effort. Also did the outer tie rods and end links while I was there.
long story short, if your on the fence just do it. Amazing ride difference, and not firm at all, just more controlled. I did the first notch, 0.6 inches. Its obviously taller but just makes the rake less pronounced. Stock tires look fine still.
JimmyH
Jimmy
TX
2023 Ford Ranger XLT Crewcab; 2020 Ford Escape SEL
Pics please. Looking at doing the same. I want just a hair removed from the rake as (1) I tow and (2) I like the wheel well space and want to add just one size larger tires to save weight. I like my MPG.
21rangerCactus
Louisiana
2021 Ranger XLT
Self employed
I'm at 104k with stock shocks... I need to replace them ASAP but I'm on the fence. Idk if I want to get the bilsteins and swap the springs or fork over the money for a set of eibachs with springs already installed to make the install easier.
TJC
2 hours is quite impressive. Did you use a lift?
Dereku
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
No, just sat on the floor. Not my first go at doing these on Fords. Nothing crazy really. Popped off the end links, CV nut, and outer tire rods, because I replaced them.
Dereku
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
I tried taking a picture, zero justice is done. Heck I cannot really tell in person. If I wanted bigger tires I would have gone the 1.2 option honestly. I could tell hopping in the first time. And the rare time I park next to another ranger.
TJC
I confess that I have not done this work on a Ford before, but simply looking at the design it looks simpler to go in from the bottom LCA than from the top. Everyone here goes in from the top, but I have seen Aussies going in from the bottom.
I surely am missing something, but for the life of me I don't see it.
Dereku
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
I did pop the upper ball joint loose too. Forgot that. Fell right out basically
jflogerzi
Moreno Valley, CA
it's even better with weight in the bed
