Bak Revolver X4s tonneau cover problems
WarpedAlien
Stan
2021 Ford Ranger Lariat Tremor in Velocity Blue
I have had the Bak Revolver X4s on my truck since 2022 and I am actually on my 2nd cover as the first one separated on the edge and now the 2nd one is also. Bak says I can get a new Revolver top or another cover. Which BAK cover should I get? The Bakflip MX4 or another Revolver X4s top?
Seems they are probably made out of the same materials with the same warranties.
brroberts
Randy
Overbrook, KS
audio / semi retired
Different problem with mine, but I’ve not been happy. I’ll definitely move into the trifold camp when it’s time for a new tonneau.
87TxAg
Houston
21 Bronco Wildtrack, 23 Ranger Lariat Tremor
Yep. I figure I’ll gorilla glue the next one one. :like:
brroberts
Randy
Overbrook, KS
My end cap did the same just as fast. I don’t remember what glue I used, but it’s still attached.
puckdodger
Oshawa
wow, that's some shitty QC.
I had the Ford branded BakFlip and it was okay, certainly no issues like that. Even though I took it off and put it back on one time it wasn't anything close to what I would call water tight from day one. And trifold does limit your box space somewhat, and can block your rear sightlines.
Now I have a different truck but it has an Enthuze soft rollup and I am very impressed with it. I remember the OG rollups would get all saggy and ugly but nowadays they have lightweight crossmembers and all that jazz. Things in there stay dry, and while it is a tad less secure than a hardshell trifold I would go with this one again if I had to replace it.
Hi Stan,
I have one for three years now with no problems.... Hmmmm, wondering if that is a defect waiting to show its ugly head?
best,
WarpedAlien
WarpedAlien
Stan
Hi Stan,
best,
I'm in Florida and it sits outside in the rain and more rain and then hot humid heat. So the vinyl doesn't have a chance like a bad convertible top.
paval3
Val
Pennsylvania
2021 Ranger XLT Crewcab & 2003 Mountaineer Premier
It is called "delamination".
AzureRanger
2006 Jeep TJ
Yikes. those cap pieces come off easy. The 1st one I threw out I stripped for parts.
Which part are you referring to as the "end cap"?
WarpedAlien
WarpedAlien
Stan
The plastic rectangular end of the rubber seals that has a pin that inserts into the hole that
87TxAg has pictured above and I have one pictured next to the label on my last pic.
WarpedAlien
WarpedAlien
Stan
Bak sent me a new Bakflip Mx4 to replace the revolver since I have had 2 tops with the revolver that have failed in less than a year each. My bed is line-x lined and as such to use the mx4 I will have to find a place to run the water lines which as I recall was the reason I opted against it in the first place. How much water actually drains down these lines? Is is worth cutting the bed liner to push the hoses out?
