justspeed7
- Thread starter
- #1
Does anybody know what size the B&O speakers are? Wanting to replace them all but there is no info online regarding sizes just need the door speaker sizes.
Do you mind sharing any photos you have on the subwoofer? I was just at a shop. The guy recommended a down-firing 8" on the hump behind the console.I dont have the B&O system but I suspect the doors and speaker holes are the same. I had 5-1/4 polkDB components profesionally installed but the shop told me 6-1/2s would have easily fit as well (with the necessary adapter rings for any size). I may upgrade in the future but im good on bass for now since I also had a 10" subwoofer installed
What is this under neath?![]()
I specifically picked the above parts for the limited space. Pioneer made the thinnest prefab box and shallowest 10in subwoofer i could find. Still, a bit of carpeting that protruded behind the subbox needed to be cut out (where the cabin pressure relief is).
Shops wanted me to get one of those powered 8in sub kits that Alpine or Kicker make for under the seat, but I knew I would end up wanting more later, so I made the effort to get this 300w 10in put in instead. It keeps up nicely with my 100w components up front.
Note: My install required an LCi2 to restore bass that the sync3 stereo removes at higher volumes. Dont know if the B&O setup does the same.
It's behind the rear seat.What is this under neath?
I used Morel 6.5 coaxials in the back and Morel 6.5 component speakers in the front that included 1.25 tweeters. The tweeters required a little modification to the tweeter location panel but the 6.5s all fit perfectly with the 6.5 adapters Crutchfield sells. I also used sound deadening in the doors that helped eliminate vibration. The Morels have well balanced highs, mids and bass that seem to work well with the original B&O tuned system. My total cost was about $500 and I'm happy with the results.Does anybody know what size the B&O speakers are? Wanting to replace them all but there is no info online regarding sizes just need the door speaker sizes.
