Auto Folding Mirror Mod Install Instructions - Pictures/Video
daczone
2020 Ranger
I've had this mod for a while and originally just wired the LOCK/FOLD wire and used the KEY ON to UNLOCK/UNFOLD the mirrors.
Well today I finished the install. I wired the UNLOCK signal wire to the module. In the Ranger is right beneath the LOCK/FOLD wire. Sadly they changed the color of these wires, or I would give you colors. For my 2020 GY/BN is LOCK and BN/GN is UNLOCK.
NOT my picture... But hopefully this will make it clear for others.
It is right beneath the LOCK wire, same size wire.
canyonslicker
Andy
2021 Ranger Lariat
65 YO Juvenile Delinquent
This method works fine for the Redtek module also. Got mine installed today. Will be installing their window modules as well.
I was curious if it would work and couldn't find any guidance for Redtek specifically. So, hopefully this helps someone else.
https://redtek.com.au/shop/ols/products/ford-ranger-folding-mirror-module
So exactly how do the window modules work? Can I lock out passenger use and still use the driver side to control them? Specifically the rear windows, I have to unlock to roll up and down. If I forget to relock them then my dog will step on rear door button and it rolls down. I can’t control the rear windows in lock mode from the driver door switches.
RDJTX
Round Rock Tx
IT Demi-God
JohnnyLightning
Orlando
2020 Ranger
Pilot
For the next guy....... The threads and videos have a bit of drift to them. It took me longer to read through them to actually do it. So here is the quick version.
I have a 2020 Ranger Lariat. This is the module I bought and the wires I used. It works as it should.
https://www.aliexpress.us/item/3256...st_main.5.67011802dqZlQC&gatewayAdapt=glo2usa
Red to fuse 30.
Gray to Gray/Brown
Purple to Purple/Green
Not my picture, But these are the wires.
C2dogs
Charlie
2020 Ford Ranger
Well Ranger (Sports) Fans, it's the bottom of the 9th and I have everything hooked up and working as per this threads instructions BUT unfold on Unlock. Other than anxiety because I am a mechanic with some electrical skills and this is a BRAND NEW VEHICLE(!) everything so far went as advertised EXECPT the Grey/Brown Wire on my truck could be mistaken for Grey/Black, this caused about 10 minutes of apprehension but I remembered I am a man and men get it done (read that as I called upon my balls to kick in :) ). I'm taking a small break to get out of the heat and hydrate so I will update Y'all shortly.
Muscleford
George
Ohio north coast
Retired CFO
I have the auto mirror fold module and continue to have an issue. Randomly they will fold when I Iturn off the engine unfold when I open the door. I have rebooted the module and checked the connections with no change. I will check the connections again.
Today I used remote start on the key fob and the mirrors unfolded upon the start, is this normal? First time I used remote start since I put.the module in.
teddys gun shop
ken
2019 ford ranger xlt
head custodian
Hello, I am a new Ranger owner. I purchased my 2020 Ranger Lariat in late August 2020. I discovered this threat as my last car had the folding mirror option and I miss it. I was wondering if this is the kit from England and has anyone had an issues with their Remote Start feature after installing the module? I read that it will not work with the Remote Start option.
R_Willis
Ohio, USA
2014 Jeep Cherokee
Anyone have tips on how to add power folding to an XLT wiring wise. I know I need replacement switch (part # AB39-17B676-AA). Already have aftermarket Kool-Vue side mirrors with the built-in motors. Thanks!
ControlNode
Eastern NC
Computers
I think that is going to depend on the year, exact trim (300, 301, 302) and options. Some of the older XLTs had power folding. I know on my 2021 XLT (301) with tech package I had to add the switch, wiring to cabin harness and added wiring to both door harnesses. I hear some say you can just buy the Lariat door harnesses so you don't need to run those wires. Seams to be about the same work to me.
The easiest way to find what is required is to use the pinout for the C210 connector
Upper Side and note are cavities 12 & 13 are filled. This is the feed from the switch connector (folding)
From your other mirror question post for the C210 pinout.
veedubtuner
Morgan
Tulsa, OK
2004 VW R32/2023 CG XLT Scab FX4 Ranger
VW Parts
Ok gang, riddle me this. What are the requirements to add auto power folding mirrors? I assumed you had have a Lariat that already was equipped with PFM but I see some of the people have XLT's and did this. I read through both threads and didn't see "You must have this option or this package for this to work" info. I'm mostly just curious, but....if its simple (and cheap :LOL:) then I may look into it more. But I already have plans for the blank spot where the fold button is supposed to be 😁
Ok gang, riddle me this. What are the requirements to add auto power folding mirrors? I assumed you had have a Lariat that already was equipped with PFM but I see some of the people have XLT's and did this. I read through both threads and didn't see "You must have this option or this package for this to work" info. I'm mostly just curious, but....if its simple (and cheap :LOL:) then I may look into it more. But I already have plans for the blank spvaraiedot where the fold button is supposed to be 😁
Here is a basic detail:
It all depends on if Ford left the necessary wiring intact on the harness.
Since there are varied options (it's like a box of chocolates) of what wiring you have on the harness as well as how the connector is pinned (If you even have the connector)
So, for full function mirrors this is the wiring diagram, if only wanting to add the Power Fold, it's just the switch and 2 wires to each door harness (add new door harness each side) or fish new wires through the door to the new mirrors.
So simple wire runs unless you want to add terminals to the OE Connectors C204 / C210 / C212
Sorry , I missed (Auto Folding) in your question.
veedubtuner
Morgan
Tulsa, OK
VW Parts
Appreciate the info, I'll be saving that. But what about the physical mirrors themselves? Are all Rangers already equipped with motorized mirrors for folding?
And what the hell happened from what I wrote, to what you quoted? I thought I made a grammar boo boo :LOL: .
I would say most likely no - as there are a few different part numbers for the mirrors
depending on the features:
Power Mirrors (Mirror Adjustment - Motor)
B/Spot Indicator
Heated Mirrors
Puddle Lamp
Turn Signal
Folding (Motor)
The parts diagrams do not really help with (Specific) details on what each part number has as options outside of the Lariat Trim.
