Auto Folding Mirror Mod Install Instructions - Pictures/Video
Discussion in 'Exterior Mods' started by RCMUSTANG, Mar 22, 2019.
  1. RCMUSTANG
    RCMUSTANG Well-Known Member
    First Name:
    Ray
    Vehicle(s):
    2017 Fusion 1995 Ranger
    Jan 23, 2019
    Los Angeles
    871
    622
    #1 Mar 22, 2019
    Original Thread Here: Auto Folding Mirrors
    Auto folding mirrors. Folds closed when you lock the truck. Unfolds when you power up the truck. Regular operation with stock switch. 20 minute install.
    The switch bezel pops right off.
    Unplug the connector.
    Plug the module in between the switch and connector.
    Tuck everything inside.
    I used an add a tap to #30 for the constant for the red wire.
    Connect the blue wire to the thick gray with brown stripe (lock).
    Stick the module on the inside of the left side of the dash and tied up all the wiring. Close up fuse panel and you're done.
    NOTE: THE ADD A TAPS SHOULD GAVE THE OPPOSITE DIRECTION THAN PICTURED.
    20190322_153420.jpg 20190322_153547.jpg 20190322_153727.jpg 20190322_155523.jpg 20190322_155515.jpg
    LightningBlue and Roofhopper like this.
  2. OP
    RCMUSTANG
    First Name:
    Ray
    Vehicle(s):
    Jan 23, 2019
    Los Angeles
    871
    622
    Here's the operation.
  3. rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,340
    2,128
    Garage Profiles:
  4. LightningBlue
    LightningBlue Well-Known Member
    First Name:
    Ryan
    Vehicle(s):
    2019 Lightning Blue XLT FX4/ 2015 Ford Edge Sport AWD/ 2012 VW Jetta/ 2010 VW GTI/ 1998 Jeep Cherokee XJ
    Feb 13, 2019
    Rancho Cucamonga, Ca
    221
    192
    Garage Profiles:
    Did your kit come with the fuse pigtail?
  5. rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,340
    2,128
    Garage Profiles:
    I didn’t order a kit please ask @RCMUSTANG
  6. OP
    RCMUSTANG
    First Name:
    Ray
    Vehicle(s):
    Jan 23, 2019
    Los Angeles
    871
    622
    The red wire with the fuse goes to a constant hot. They're are several unused ones
  7. ulev1st
    ulev1st Well-Known Member
    First Name:
    Don
    Vehicle(s):
    2019 Ranger CC FX4 ,2012 F250 Lariat FX4, 2017 Shelby GT350, 14 Ford Focus
    Feb 15, 2019
    West Tn
    92
    102
    Occupation:
    Retire Marine and Refinery Operator
    Garage Profiles:
    I am assuming the green wire from the kit hooks to where you have the other tap shown? It is also green/ white. Is that correct?
  8. OP
    RCMUSTANG
    First Name:
    Ray
    Vehicle(s):
    Jan 23, 2019
    Los Angeles
    871
    622
    No, that is if you want it to unfold everytime you unlock the doors. The way I have it is fold when you lock and unfold when you turn on the accessory/ignition.
  9. ulev1st
    First Name:
    Don
    Vehicle(s):
    Feb 15, 2019
    West Tn
    92
    102
    Occupation:
    Garage Profiles:
    So you leave the green wire alone and just loop it up out of the way?
  10. OP
    RCMUSTANG
    First Name:
    Ray
    Vehicle(s):
    Jan 23, 2019
    Los Angeles
    871
    622
    Unless you want it to unfold everytime you unlock.
  11. Jrye22
    Jrye22 Well-Known Member
    First Name:
    Jon
    Vehicle(s):
    2019 ranger lariat
    Feb 20, 2019
    New Jersey
    158
    158
    Garage Profiles:
    What amp fuse are you useing all the add a fuses I can find are max 10 amps and the fuse that was in your number 30 what amp was that?
    Gus Villalpando likes this.
  12. j0shm1lls
    j0shm1lls Well-Known Member
    First Name:
    Josh
    Vehicle(s):
    Oct 30, 2018
    SoCal, USA
    769
    748
    Garage Profiles:
    29 and 30 are both 30a fuses, just throw a 10a in the add-a-fuse and you should be good.
    Jrye22 likes this.
  13. j0shm1lls
    First Name:
    Josh
    Vehicle(s):
    Oct 30, 2018
    SoCal, USA
    769
    748
    Garage Profiles:
    if you plan on leaving the inline fuse intact, then no you don't need a fuse in the add-a-fuse. There are a few other options such as a 'fuse tap' like this
  14. OP
    RCMUSTANG
    First Name:
    Ray
    Vehicle(s):
    Jan 23, 2019
    Los Angeles
    871
    622
    Actually, it's too tight for those. Believe me, I tried one before I paid for another set of add a taps.
  15. ulev1st
    First Name:
    Don
    Vehicle(s):
    Feb 15, 2019
    West Tn
    92
    102
    Occupation:
    Garage Profiles:
    Autozone $4.99
    ebFX4 and ToothRanger like this.
Share This Page
