Anyone use the Ford Bed Cargo Net?
Voltune
Washington State USA
Ranger 2019 XLT 4x4 Supercab (302A)
New Ranger owner here. I am thinking of purchasing the Bed Cargo Net offered from Ford Accessories.
Part No: KB3Z-99550A66-A
https://accessories.ford.com/bed-products/cargo-products/net-asy-load-fixing-12137.html
The website says it “Requires Bed Standard Interface Plate and Bed Cleats.” I called a dealer parts department and they said they didn’t have a bed standard interface plate in the system for a 2019 Ranger, only for an F-150. They were baffled why the website had this info on it. They said I should be able to use the factory stock tie downs that are already installed in the bed. Nothing else should be needed.
Anyone have this bed cargo net for the 2019 Ranger and can confirm it doesn’t need any extra hardware to attach it?
fusseli
EE
Haven't tried it, no.
I have an old generic elastic cargo net from a roof rack that fits the bed when stretched. They are dirt cheap on Amazon
FULLSCALE
Adam
Ontario, Canada
By the look of the pictures it seems that it just attaches to the factory tie downs.
toddyfunk
Todd
Denver, CO USA
2022 Lariat Ranger Tremor, Tech 501a, Tow
IT Management
I bought a similar one off of amazon and it just clips to the in bed tie downs...
Blue Streak
Larry
I just purchased one at Harbor Freight cheap. Needed one in kind of a hurry. All though the netting grids are larger I only want it to hold light bulky items occasionally. I took a rope tied it to one factory tie down then looped through all the rest back to the first. This lets me hook the net to the rope any place I want.
Hi Folks,
Not sure why you need bed nets...but ii it is for wind-resistance reduction for fuel economy, you are sadly mistaken. I have tested in the wind tunnel on F Series and Rangers with tailgate up and tailgate removed...The aero horsepower was degraded by the tailgate removed. Air flow is not intuitive... If you really wish to affect the air that tumbles off the cab...put a 6" wide strip at the back over the tailgate...you will get a aero hp gain...
We did this on on our Desert racing teams with good results which including another $5 dollars of duct tape. We knew we had success when the drivers of the top class Trophy (Trick) Trucks resulted with the drives complaining that their helmets were being sucked off their heads at 140mph on the dry lake beds...something they had never experienced before in the race trucks...
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
if anyone parked a truck loaded like that in my neck of the woods, even for 10 minutes, you'd find it barren and empty in no time. thieves love pickups full of items like that.
Motorcycle and generator had a kryptonite cable with a good lock just in case. They can have the water and little compressor lol where do you live?
pa-fatboy
Rich
Reading, PA
2019 Ford Ranger, 2016 Mustang GT Premium, 1966 Mustang Convertible C Code, 2019 Ford Fusion, 2005 Ford Focus ST
I have the ford cargo net and use it with my 5ft. bed Ranger. It uses 4 clips to lock all corners down. What ever you want to secure goes under the net which has an adjustable cinch on it to get it reasonable tight.
For me, it was well worth the price for something less than $50 that can keep a wide range of items stable in the bed. When not in use, it folds up and can be stored under the rear seat.
outdoorphotog
Ian
Healdsburg, CA
2019 Lincoln Navigator L
Limo Driver
I purchased the cargo net from Ford, for me it attaches to all the existing tie downs. I wish it had a bit more elasticity as its mostly hard rope, i would probably get one on Amazon if i had the option again.
