Bed Cargo Net Recommendations
TICKLE ZOMBIE
Florence SC
2022 Ranger XLT 2WD Sport
I’m looking for recommendations for a cargo bed net. I’ve listed 3 from Amazon. Anyone have those or can you recommend something else?
I do not plan on hauling huge items, mainly fitness gear (not machines or weight racks) mostly.
Thanks!
No experience, but I'd go for 2 or 3 over 1.
Danager
Dan
Alberta
2019 Edge
Manager
I have one similar to your first option. That is the style I recommend. It helps to have a plan of where you will attach to and the height of the average load over that - so you can calculate the size needed. In my case, I want to keep things put on the bed slide and remain under the tonneau cover - which is 17” up, 20” across, 17”back down, and 60” long (technically 17” up/down again from and rear). So I purchased one that is 72” x 60”. It had these terrible plastic hooks that I cut off and just use carabiners through whatever piece of the bungee that makes the most sense.
I had one of those heavier ones for a week and returned it. Some have some flex in them, Mike didn’t. It took a lot of adjusting every time I used it. I did not need anything near the load rating it had. It also took up more space when not is use. If I need, I can throw on one of the ratchet straps I have collected.
Cabose-1
Eli
Student
Wally world has one thats pretty inexpensive and works pretty good. About 20 bucks if i remeber correctly
Superbuggy
Max
OH
2022 Ford Ranger XL STX 4X4
Thanks!
I have a stretchy bed net similar to the first one you’ve shown. I have used mine quite a bit, and it has served me well. I like how it is adjustable for various size cargo, and it has held a tarp down over cargo on 5 hour highway trips lately. Long story short, I’d get your first choice.
