Anyone ever drill/tap into your back cab wall?
veedubtuner
Morgan
Tulsa, OK
2023 CG XLT Scab FX4 Ranger
VW Parts slinger
Curious if anyone has ever drilled into the back cab wall behind the rear seats? Like if you did stereo upgrades or deleted your rear seat and drilled, or used nutserts for mounting things?
I have been thinking of putting a universal molle panel back there since I did the seat delete. Mounting it is where I have some concerns. Mounting directly to the back panel might not be ideal as it is not hard plastic, it's like carpeted fiber board that's kinda flimsy, and I feel that the weight of the panel will cause it to rattle against the back metal cab, especially off roading. So I have been tossing around the idea of doing nutserts, maybe with some nylon or ABS spacers (if needed depending where the holes would be placed) then screwing right through the carpeted back panel into the nutserts. Anything to worry about or be aware of behind that wall (besides the bed of the truck :LOL: ) like wiring or anything?
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
I have used well nuts in thin steel successfully. They're an expanding rubber rivnut that eliminates vibration. Also have a set of tiny step drills for thin steel that don't catch.
veedubtuner
veedubtuner
Morgan
Tulsa, OK
VW Parts slinger
No but if I was going to, this is where I’d drill.
That's exactly where I was thinking for the top. Hopefully the bottom has the raised sections in the right spost for drilling as well, they're kinda random lol.
Fordup
Ed
NY
youtube.com
This is an Amazon link to similar ones. I got them at my local Runnings in the hardware drawers. Any big hardware store should have them.
https://amzn.to/4xRlh21
veedubtuner
veedubtuner
Morgan
Tulsa, OK
VW Parts slinger
TJC
I'd use those loops (circled in green) to secure the bottom. Cut a piece of fuel line hose to length of the metal loop ( the ID of the hose the same size as the steel loop), Slice it lengthwise and wrap it around the metal loop. It protect and secure you panel and the loops, and minimize vibration rattles. What ever fastener you use will bite into the hose securing the bottom of the panel.
And I'd also use a drill bit depth collar to insure I didn't drill through the back of the cab.
There are many designs, and the link above is an Amazon search result showing all the different styles. This is cheap insurance.
Fordup
Ed
NY
youtube.com
These are the actual drills that I use on thin metal to get accurate holes without pulling through at the end. Be careful because thin metal is tough to drill and work hardened from forming.
Rtball
Central Florida
2019 F-150 Platinum, 2020 Escape Titanium, 2021 Ranger XLT (FX2), 2022 Ranger XL
Retired Air Force and Car Hauler
Hey a bunch of good advice items from the "Tech-Men" at 5G Forum! I have no need for this info at this time, but maybe in the future. Thanks Guys.
veedubtuner
veedubtuner
Morgan
Tulsa, OK
VW Parts slinger
Just checked Amazon...:shock: pricey little buggers lol.
ScarzRanger21(2.0)
Eric
Auberry, CA
Electrician
Get some L-brackets and anchor them to the floor. That’s what I would do.
You could always use L brackets for the bottom and anchor it straight to the floor. Might need to pull back or trim some of the carpet.
twk
Minnesota
'17 Mustang GT drop top, '22 Ranger Lariat Fx4 SCABbie.
Flight Simulator Engineer, retired, unemployed, burden on society.
CashSeeAO
Central New Mexico
2023 Ranger XLT Super Crew
I have used nutserts (M6 size) on the raised section of the back wall. That was my first time doing it. One of the two did come loose after a couple of weeks due to my amateurish first attempt. Should have practiced a few times before doing it for real. One of the best reasons to use nutserts is it facilitates frequent removal and reinstall.
