Another GFB DV+ review
TORQUERULES
US
Ranger
Just installed the GFB DV+ on my Ranger which is also tuned and running a 93 octane Performance tune from 5-Star. I installed it with all of the provided springs to give a more progressive actuation (what they call a "Sport+" feel) and I must say that I am surprised at how noticeable the improvement is. The throttle is more linear and between-shift recovery is instant and smooth. I recommend it as a nice drivability upgrade as well as the added performance from near instant boost recovery. I lubed it well and plan on doing that once a year for preventive maintenance. I might even buy a back up in case any of the hard parts such as the plunger begins to noticeably wear as I plan on keeping this truck for quite a while.
Mustang2Ranger
Garrett
Southern California
Good to hear, that is exactly what I was hoping for. Mine came today so I will be installing after work
Doc
Doc
Live oak fla
For the backup, buy a turbosmart..
Regards
r1ch999999
Rich
Nashua, NH
Software Engineer
What do these things do for the engine?
kieefer
keith
Only thing I noticed is that it needs re-lubing now and then.
TORQUERULES
TORQUERULES
US
Ranger
For the question about what does it do for the engine, if you wonder if there is a power increase then no. It helps with boost recovery after shifts or throttle tip in as compared to the stock BPV. This leads to a little more responsiveness. To the comment about sound, this is not the ricer vent to atmosphere until. It still uses the stock bypass tubing and is as quiet as stock. Maybe a little different sounding than stock due to how and when it bypasses, but like stock you cannot even hear it most times and must be really listening when you do. It is a drivability modification, nothing more. No Fast and Furious bulls**t for me...
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I put mine on for (hopefully) refinement in shifting and throttle under boost and durability of the stock wastegate. Once I get the tune from Unleashed hooked up I'm hoping it will really make the power train seem more fluid.
TORQUERULES
TORQUERULES
US
Ranger
Exactly! More fluid. I was surprised it made that much difference, but shouldn't have been. In previous turbo builds I have found that a well designed BPV or BOV makes a ton of difference. Plus, when you turn up the boost you need to upgrade it, along with good wastegate control, to hold that boost steady.
SubVet
Myrtle Beach
Doc
Doc
Live oak fla
