Another failed AC. 39k miles. 2019
kendive
Ken
23 Ranger Lariat Tech Pkg Tremor
I think the design is different in an F-150. I had my whole plenum replaced under warranty; yes it's an all day-er on a Ranger.
The plenum under the dash gets warped because there is hot coolant running through it at all times. This causes the actuator(s) to bind or break, preventing the blend doors from moving. so if they get stuck open, you have 195ºF heat only.
Apparently this is cheaper than having put a ball valve with a step motor on the inlet hose in the first place, so there isn't coolant running through the heater core all the time.
Probably but I would still try to tackle myself. :) There is always a better way than what a dealer would do and I would know it was done correctly. Ford dealers scare the crap out of me.
Motorpsychology
Prescott, WI
Vagabond
I wish you success, Ken. Like nearly everything else automotive, there is a bunch of stuff to remove to get to the HVAC plenum, For example, the entire dashboard, APIM, and careful with that Airbag!
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
AZ Scorpion found an easier way to do it. There is a post on here. Iirc drill a hole through some sheet metal by driver side footwell for access and then just manually turn the actuator, one way for winter, the other way in spring.
kendive
Ken
I know but would not scare me. I have done way worse. My truck is brand new so hope it does not fail... I also have mess with airbags before. I replaced the clock spring in my wifes Honda CRV we use to own. I bought her a new Rav4 Hybrid not too long ago.
I will be quite honest. I will probably be back in an F150 some time or another. There is alot I miss.
BUT The Ranger is fun to drive for now... We end up with another camper I would move back to the F150 for sure.
Gibs45
Redondo Beach
2021 Ford Ranger Sport 4x4 Cactus Grey
Sales
Was this problem fixed after the 2019 model year?
Motorpsychology
Prescott, WI
Vagabond
My 2021 (4/21 build date) had to have the plenum replaced. I don't see any posts from 2023 owners, but it's early and 2023 was a short model year.
Ronbo
Ron
FL, CT, TX
2019 Ford Ranger XLT FX4+
2019 Ranger FX4 “Unicorn Edition”. No problems with mine.
Motorpsychology
Prescott, WI
Vagabond
Langwilliams
Langley
Lorain, Ohio
I was thinking the climate you lived in might contribute but I guess it happens everywhere. I know a few people in AZ had the problem.
My 2019 with 46K was fine when I traded it in. I had the extended warranty to 75K just in case for this reason.
If the actuator lasts six months an it's $18 I'd be tempted to just buy a couple an change them when needed. I tend to get rid of vehicles after 50K. If you plan on running it a long time might have to bite the bullet an hope for a discount from Ford.
