TomC
- First Name
- Tom
- Joined
- Nov 6, 2020
- Threads
- 8
- Messages
- 389
- Reaction score
- 1,287
- Location
- Florida and North Carolina
- Vehicle(s)
- 2020 ranger lariat supercab FX4
- Occupation
- Family vehicle MX officer
- Thread starter
- #1
Anyone here use a dump trailer? Thinking about getting one of these, or something similar. 7K tandem axle. I have had cargo trailers before, but not a dump trailer. Any insights, or concerns? Any brand sold in the Southeast I should look at? info here. Happens to be Texas pride trailers, but I know very little about them.
7k lb GVWR 10' Bumper Pull Dump Trailer - Texas Pride Trailers
Walk Around: 7K lb GVWR Bumper Pull 10' Long Dump Trailer | Texas Pride - YouTube
G.V.W.R.: | 7,000 lbs |
Empty Trailer Weight: | 1,800lbs (5'x10' dump, no additional options) |
Net Payload Capacity: | 5,200lbs (5'x10' dump, no additional options) |
Axles: | Dual 3,500 lb Direct Lube 5 lug (electric brakes on one axle) |
Suspension: | Double eye springs |
Brakes: | All wheel electric brakes on one axle (10" x 2" brake shoe) |
Tires: | New 15" ST205/75D15 LRC 6ply (1,820lbs ea) |
Wheels: | 15" x 5" five hole white or silver (based on stock) |
Main Frame: | 4" x 2" x 1/4" wall rectangular tubing |
Tongue: | 4" channel |
Tilt Frame: | 3" x 2" x 3/16" wall rectangular tubing |
Cross Members: | 3" channel |
Bed Flooring: | 1/8" thick sheet steel |
Bed Siding: | 1/8" thick sheet steel |
Tie Down: | Stake pockets |
Deck width: | 60" on 5' wide; 76" on 6' wide |
Deck length: | 10' |
Deck height: | Approximately 24" |
Side Wall Height: | 18" on 5x10, 24" on 6x10 |
Rear Door: | Single swing door (5x10), Double swing doors (6x10) |
Battery: | Group 27 deep cycle marine |
Charging System: | Onboard 110v charger and tester (also charges off truck while being towed) |
Pump: | Electric over hydraulic (1.7 gpm) - power up / gravity down |
Controller: | 15' corded remote control |
Toolbox: | Front locking tool box - contains battery and pump |
Hydraulics: | Single 3.5" x 24" hydraulic cylinder (10,000 lb max rated capacity) |
Coupler: | 4 hole adjustable height 2 5/16" ball |
Safety Chains: | Two heavy duty safety chains |
Jack: | 7,000 lb drop leg jack |
Fenders: | 14ga heavy duty tread plate |
Lighting: | All flush mount or recessed lifetime LED stop / turn / clearance lighting |
Wiring: | U.S. made sealed modular wiring harness |
Safety Equipment: | DOT required emergency break-a-way kit and conspicuity tape & Prop Rod |
Finish: | Fully primed and painted with automotive grade acrylic enamel |
