4x4 Malfunction Warning
bsr956
Brian
Lenoir, NC
2020 Ranger XLT 4X4; 2013 Nissan Altima
On Saturday I drove it to church for Men's Ministry workday w/ no issues. Started it to leave and got the wrench icon and a 4x4 shifting malfunction warning message on the gauge cluster. Pulled into a gravel parking lot and it would not shift into 4x4 at all, drove it home and it sat for around 1 hour while I was doing other things. Cranked it to put into the garage - no error messages. It shifted into 4x4 high and low several times without any issues. Drove it Sunday, no messages, shifted into 4x4 high & low without any issues. Drove to work today with no error messages. One off issue? Should I be concerned? This happened to you??
ControlNode
Eastern NC
Computers
Could be a one off, could have been the timing of key in ignition to on, or on to start even. If one of the modules didn't get the response it expected from another module and timed out the wait for it, these random seeming errors can happen. Often a full power cycle (not just ignition off/on, nor going as far as battery disconnect) can clear them up. I've had my RS and Ranger each so odd things randomly, but it's fairly rare and normally turning it off, opening and closing the door and then waiting about 5 minutes, if you watch the gauges closely you can sometimes see when it actually powers down and not have to wait the full 5, it seems to be fine.
Most Likely:
Sticking 4-Wheel Drive Relay, this relay is powered from 2 sources - before and after the PCM Power Relay. The relay is integral to the Engine Bay Fuse Box.
As posted above, once the modules time out and go to sleep, power fully dropped off and the relay relaxed and deenergized.
Living The Dream
This type of error does not bode well for long term durability :confused:
Is the relay separate, or is it similar to the Chrysler TIPM (Totally Integrated Power Module) debacle where a sticking horn relay costs several hundred dollars and a trip to the dealer to reprogram the new TIPM to your vehicle?
There are 3 relays related to 4-Wheel drive
1 ea - Intergrated into the Fuse Box (Not Serviceable)
This relay energizes when the PCM Power Relay energizes, so (Wake Circuit and Key Transition to Start/Run)
2 ea Relays (Serviceable) CW Motor Relay & CCW Motor Relay, mounted on top of the fuse panel,
these 2 relays only power when you are shifting (to & from) 2wd-4-Hi and 4-Low
bsr956
bsr956
Brian
Lenoir, NC
Who knew it was sooo much work to press the clutch and pull the lever to engage 4x4?? :shock:
LawnMM
Rich
'23 Ranger Tremor
Mines got less than 2500mi on it and I got a 4x4 warning message once. Power cycled, gone, nothing since.
These trucks are so increasingly computer controlled think of them like the computers on your desk. I was big into building my own PCs in the late 90s early 00s and you wouldn't BELIEVE the crazy manifested problems you could fix on a computer with a simple power cycle.
Memory leaks, disk fragmentation, all kindsa crap gets cleared out of degree on a power cycle.
If the error is repeatable that's more concerning.
Jason B
2021 XL STX SE 4x2
machinist
I long for the days of my 99 Ranger so much stuff to go wrong on the new vehicles.
Well, those 4x4 actuator motor and switches could be troublesome, and don't get me started on the Pulse Vacuum Hub debacle Ford used during those years.
  • Haha
Reactions: TJC
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Got this message for the first time today. Haven't driven for a week and since last time I had cleared the KAM using the Livernois tuner. Noticed that no lights are lit on the 4x4 dial when the warning was on.
Parked for an hour while watching grandson at his bowling tournament and everything fine, no warning and 4x4 shifter was lit and engaged it with no problem.
Dang gremlins.
Tremor-R
Scott
Belton, TX
Agriculture Chemical Formulation
Yes, this happened to us. Same error lights. Check your main fusebox (under hood, drivers side against cowl) for water inside and possible corroded terminals. Unfortunately for us, ours put itself in 4-low when we were going 30+ mph. I'd run it to the dealer and have them take a look at what I mentioned above.... drive carefully.
Cabose-1
Eli
Student
Probably a one off. Like the chimes in my truck sounding all wonky. Only happens once in a blue moon. Its all the computer software. Just does not sync at times
RangerBill
It might be useful to read any DTC's to see what's up.
Andrew27
Andrew
Missouri
23 Ford Ranger, 95 Ford Explorer, 98 Ford Ranger
Auto Technician
My in-laws 2023 had this happen a few weeks ago in Wisconsin when it was near -20 degrees. The next key cycle it was off and has stayed off. I told them to chalk it up as a freak thing due to the extreme cold.
TJC
Rhetorical Question - Why in the hell would they make a relay "Not Serviceable" ???
It IS a relay! Relays fail!
The idiocy of these engineering decisions continue to amaze and stun me.
I guess it right up there with not having tail light bulbs / LEDs that are replaceable. Why spend $5-$15 when you can charge $800 when the tail light goes dark.
