4WD Advice please!
Langwilliams
Langley
Lorain, Ohio
Automotive purchases are all about what we want not what we need
Exactly. I don't need a 500 HP mustang but I want one. I don't need my 25K Harley that I only ride 8 months out of the year an then only on dry days but I like it. Same goes for mods. I didn't need the extra 50 HP from a tune but I'm glad I have it.
Jms81661
Las Vegas, NV
2020 XLT Ranger Sport
Truck Driver
Meh...I use it to get on the freeway in the rain. These things slide all over the place when the turbo kicks in. It's fine
seanellaz
Sean
Tucson, AZ
Healthcare
First Ranger, first 4WD and I'm really happy but it has occurred to me that I really have no idea what the capabilities are.
One of the selling points for 4wd is added safety during adverse weather conditions. I figured four on the floor would help especially in rain but now I see that Ford doesn't recommend 4X on pavement. Huh?
So I'd appreciate your feedback readers. Can I use 4X Hi without problems on paved surfaces? Am I looking at potential tranny problems now or in the future?
I grew up a mile down a dirt/ mud road and that's more off roading than most people I know. I suppose what I'm asking is that if I'm not an off roader, did I kinda waste $ on 4x?
I have used 4wd hi range in heavy rain @ hiway speeds. The truck loves this. On dry pavement with curves the system might build up tension / bind due to unequal wheel travel. If you will drive in mud or snow 4wd beats 2wd any time.
Gsxrdoug
Hawaii -- Oahu
2021 ranger, XLT 4x4, Cactus Gray
Therapist -- Retired Navy
I made a short video of driving in two wheel drive. Did not switch into 4WD until you see me bobble around 3:45 of the video.
Nice video but whats all the white stuff everywhere?
thellamafarm
Mitch
Ranger 19' XLT
Same. I value my life and safety more than my truck. If I feel safer and more confident in 4wd I'm putting in in 4wd. I don't see why so many people are pushing against 4wd. Its your truck do what you want with it. In Michigan, 4wd is a must, even if all these so called experts say you "don't need it". Well I can tell you more times than I can count how 4wd saved me from sketchy situations. And no its not cause I needed to "slow down", the opposite is true in snow when you need to pull out a neighborhood where the snowplow trucks create 4 foot deep banks of snow and pulling out is a 50/50 shot of getting hit by a car blasting over the hill...
DakotaGuy
Tom
Black Hills, SD
2022 Ranger SuperCrew XLT Tremor
Also keep in mind that when you use 4x4 in snow, that it helps you go. It does not aid in stopping. Don't get over confident and slam into something.
It also helps a lot in keeping the vehicle from spinning out and skidding on a road, but you are correct in that it will not help stopping.
DakotaGuy
Tom
Black Hills, SD
My 2013 F150 had the vacuum operated hubs. After 8 years, <50k miles they both failed to fully disengage.
The Ranger doesn't have vacuum hubs. It hasn't had them since 2001 IIRC. The front axle shafts are permanently bolted to the hub. This means that the front driveline is always engaged and spinning at vehicle speed. It is only disconnected at the transfer case in 2WD. This also means you don't really need to worry about using 4WD to "lubricate" the front driveline on a Ranger, because it's already spinning.
As far as I know the F-150 still uses a vacuum hub set-up. The Ranger has such little drag in it's smaller and lighter (vs the F150) driveline that there is no reason to disengage it. It actually makes the 4x4 system more reliable and quicker to engage and disengage. The only negative is driveline wear, but modern drivelines can last a very long time.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
One thing I have always said is if you don"t know what you are doing all 4wd does is get you deeper into shit.
One thing I've always said is that 4wd goes better in snow but doesn't stop or turn any better.
