37s on 6 inch lift
serp
Christian
Charlotte
Hey has anybody ran 37s on a 6 inch rc/bds lift I’ve seen 35s but curious the amount of cutting to run 37s.
Thanks
Squatchranger
Orlando
19 ranger lariat
Thanks
37's are gonna be heavy and have a ton of rolling resistance. our trucks are not geared for that 35's are doable depending on what tire you use but even then it can be hit or miss. I would be less worried about clearance and more about the gearing, also 35's fit with a 3.5 just fine full articulation so going 2.5 inches higher lift wise and 2 inches higher tire wise should work as long as you get 12.5 inches wide I can't speak for any wider than that.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Biggest lift I’ve seen available is 6” and on BDS’s website it says 6” will fit 35’s.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
This is the point you jusy need to do a full prerunner build. A BDS lift kit and 37s is almost pointless. Minimal wheel travel and mosy likely a terrible ride. Unless this is just for looks and not practical use.
Widening the stance allows more wheel travel, gives the shocks leverage over heavier tires, and requires fiberglass fenders which would clear the tires.
dirtystevedirt
Spokane
2020 Ford Ranger
cnc guy
I'm sure Jared Baker is in here not sure on his user name. He did a total of 7.5" lift and runs 37s
ScarzRanger21(2.0)
Eric
Auberry, CA
2021 Ranger 4x4, 2019 Ranger Fx4
Electrician
Did you ever get a final for this question? I was wondering the same thing. I’m gonna buy the mother-in-law’s Honda civic and use that as my daily driver. Planning on converting the ranger into an offroad monster lol
