2019 Ranger Engine made sludge
TJC
We're the opposite as I've always done mine up until 2011. I started with my parents cars back around 14 or 15 and it helped all my friends had older brothers who were huge gear heads back then in the mid 70's. It wasn't uncommon for us to be hanging around (mostly bugging them lol) getting parts or tools and learning how to do things.
When I moved to AZ and was just to hot there most of the time and I had a great shop just down the street. They'd do their version of the "Works" for me with a full synthetic oil for $80.00 OTD. For that price it wasn't worth my time doing it but now I need to find a good shop around here. If I can't I might just start doing them again because we'll have much better weather in the spring and fall here.
Put a lift in the garage, and make it with a 12' - 14' ceiling. Do it now while you are building the new home. :)
With Air Conditioning and heat!
Jedadiah
Jed
Central Kentucky
Former '21 SuperCab Owner
I'm no expert, but I'm comfortable with the recommended service intervals from Ford as long as the truck is being driven routinely. Then only time I didn't drive 10k in a year was during the pandemic. Not being driven is harder on a car than anything in my experience. If I don't drive 10K in a year, I'll change the Oil. I bet one of the reasons Ford doesn't use Zero Weight Oils is so that they hold up longer. Our Subaru specs 0W20 and has 6 month/6K intervals. I had Volkswagen's with the 10K/1 Year intervals and they all used 5W30 as well.
It's a good sign that he hasn't been able to source a 2.3 from a Ranger. That one was clearly abused.
Trust me I thought about it and it's still on my list. I haven't even broke ground yet and we're racking up the overages already. I expected this (thought I'd go around $20K over) but there's so many more important things I'll get more/better use of than a lift. Like I said earlier I just don't enjoy working on things like I use to and cant see spending extra money on a lift where I'd only use it maybe two times a year at most.;)
I'm going to have it pre-wired for a mini split. Since I'm doing spray foam in the garage (along with the whole house) and added an insulated garage door it only makes sense to add this and wont be much extra. Then I can wash and detail my truck in comfort all year round. Plus have a place to sleep if/when I get the boot when Annie's mad at me. ?
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
Run hot and cold water lines to the garage.
They're already on my spec list.? I have hot/cold spigots going along the water heater wall in the garage with a drain in the center of the floor. I also added 2 sets of LED strip lights (front & rear) to both bays in the garage. I hated only having one and nothing but shadows. I'm going to epoxy the floor before we move in because I know I'll never move everything out again to do it. lol
Bob902
St. Louis
2021 Ranger XLT
RETIRED!!!!
Our last house had both. Moved to our current house and didn't have any hose spigots in the garage. House was built in 2015 and I thought it was strange not to have them. So, I ran both lines to correct that annoying oversight.
seasprite
seasprite
Missouri
2022 Ranger XL STX
I was looking at it more from the perspective of general mileage and condition. Lot's of folks talking about walnut blasting for DI engines. I'm still waiting for someone to boroscope their intake valves here :)
Thought someone did post a some pics of one cylinder #2 or 3 due to restrictions on getting the camera snaked in there. Just don't remember who.
TJC
I get it on doing the work yourself. It gets tougher the older you get. I still use my lift, but I'm real close to 70 and things have gotten harder in the last 5 years.
My attached garage is insulated including the door. Bringing a hot car into the garage will heat up the bonus room above the garage. I use the detached garage in the summer for the active cars unless it is raining.
TJC
Time your 6 month oil change intervals for early spring and late fall. Humidity in the south is lowest over winter, and temps are mild - in the 50's and 60's. For me it is perfect wrenching weather. Avoid summer (generally May - Sept) like the plague! 90F+ with 80-90% humidity is terrible,
When I did them in the past back east that's how I'd try and time them. Although my F150's were easier because they were higher and no skid plates to deal with so I could slide right underneath and change it pretty fast.
We've had a few humid days but honestly nothing unbearable yet. These last couple mornings it's been around 66 degrees, a lot nicer than AZ where it was usually 85-90 at 5am. ?
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
That was a good video. I really enjoy Eric's videos. I learned a lot from it. I do my oil changes at 3000 miles. I know Ford says 6000. But I'm just an old fart about that. I was also glad to learn that the oil pump was not wet belt driven.
Sadly the new Ford Ecoblue 2.0 Bi Turbo diesel that is the standard fitment engine over here (unless you want to cough up $3,000 extra for the 3.0 V6 diesel - and I would), has wet rubber belt driven cams and oil pump. They're actually quite nice engines - when they're new, with an impressive 210 Hp output, and commendable smoothness and economy.
But there are already reports of multiple failures from the UK where the same engine has been used in the Transit van and light truck for some time. To the point where Ford has had to lower the expected life span for belt changes and (forced to) replace many failed engines,
Unfortunately these are the types of issues that often don't always show up in "computer simulations" or just running an engine on a test bench for the equivalent of the "average" car life.
Hmm lets see, rubber under enormous stresses, bathed in hot, dirty diesel oil for 15,000 km at a time - what could possibly go wrong??
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Yes that's true, whenever I consider buying another car, I have quick look online to see what the average price for wrecker salvage engines is, if they're plentiful and cheap, that's a good sign, because obviously they don't fail often, or sell many, on the other hand they're asking silly money for even crappy looking ones, that's a red flag.
JHRODD
JEFF
Friday Harbor, WA and Tucson,AZ
2022 Ford Ranger FX2 , 2024 Mercedes Sprinter
RETIRED
I just built a house in Tucson with a mini split, heat pump water heater, spray foam on the underside of the roof, R23 BIBS insulation in the walls. It's all electric and our June bill was $83 , July was $81. We payed close attention to air sealing with ZIP flashing on all the windows and penetrations. We have a lot of glazing. The power was out for more than a day a couple of weeks ago and the interior temp only went up 3 degrees.
