2.3L EcoBoost SP-594 Spark Plug Change Write-Up (60k Miles)
Trash Panda
Cody
Greetings all,
Thought I would do another one of my write-ups on a fairly simple, yet important maintenance task on your Ranger. (This guide is geared towards those of us who have never performed this procedure)
The Ford Scheduled Maintenance is "Every 100,000 mi (160,000 km) Replace Spark Plugs."
The spark plug specifications are gap (0.027 - 0.031 in (0.70 - 0.80 mm)) and torque 12 Nm (106 in.lb (8 ft.lb))
Supplies Needed :
-4x Motorcraft SP-594 (CYFS-12Y-RT3) Spark Plugs (Our manual states SP-578 but SP-594 superseded it) ($57 total from my local dealer)
-3/8" Ratchet or 1/2" Ratchet with 1/2"-3/8" adapter (You can use a cordless like my Milwaukee 2457-20 to remove bolts after loosening them with your ratchet)
-8mm and 10mm semi-deep or deep sockets
-5/8 Spark Plug socket
-6" or 8" extension (I used a 6 inch with no issue but an 8 inch fit just fine as well. If you have a wobble extension it can help on cylinder 4)
-1/4" in.lb Torque Wrench set to 106 in.lbs (12 Nm) or 1/2" ft.lb Torque Wrench set to 8 ft.lbs (11Nm)
-Plastic/Trim Clip removal tool (I used a Craftsman CMMT98373) or small slotted head screwdriver
-Dielectric Grease (Permatex 22058)
-Straight Pick (I used my Matco PMO1C)
-Old microfiber towels
Optional :
Step Ladder or Work Platform
-Compressed Air or Forced Air Unit (I used an Adam's Air Cannon)
-Nitrile gloves (can't forget about PPE)
Step One :
Remove the EcoBoost Engine Cover if equipped (my '19 Lariat came equipped) by removing the 2x 10mm lock nuts and pulling up
*OPTIONAL: Upon removal deep clean the cover and underneath around the spark plugs using a damp microfiber rag or brush
STEP TWO :
As I mentioned in Step One, clean as much as you want on the top of the engine using low pressure compressed air to blow out large particles and using damp microfiber towels. I opted to clean as much as I could to prevent anything from falling in to the cylinder holes.
STEP THREE :
Drive up the road or get your family some breakfast like I did to warm up the engine prior to disassembly. I am a Quality Engineer so I follow procedures. :LOL:
The procedure states "Do not remove the spark plugs when the engine is hot or cold soaked. Make sure the engine is warm (hand touch after cooling down) prior to spark plug removal.
STEP FOUR :
Use your plastic clip removal tool or slotted screwdriver to remove the 3x plastic wire guides/retainers. It is super easy and you do not have to apply much force at all. You can pull the harness away from Cylinder 1 (closest to you) to fully expose that ignition coil now.
STEP FIVE :
Unplug the 4x Ignition Coil connectors. The design is pretty neat, the white sliding locking tab can be unlocked by using your fingernail and sliding it away from you. Once the locking tab is unlocked, simply wiggle the connector off.
STEP SIX :
Use your Ratchet & 8mm socket to remove the 4x Ignition Coil Studs and use a twisting motion to remove the Ignition Coils (mine did not take much force at all). The trickiest one is the back one on cylinder 4, but simply rotate the Ignition Coil clockwise where it is not obstructed by the high pressure fuel pump and pull up.
STEP SEVEN :
Remove 4x Spark Plugs using a 6" or 8" extension with a 5/8 Spark Plug Socket. Mine were fairly easy to break loose and did squeak a little bit while loosening.
My plugs were in decent shape, but I am probably going to make my change interval 5 Years/60,000 miles. The staining on the porcelain is not rust, it is corona staining and is a completely normal byproduct per NGK.
STEP EIGHT :
Check gap and Reinstall your 4x new Motorcraft SP-594 Spark Plugs. All 4 of mine were at a 0.029 inch (0.74 mm) gap out of the box so I did not adjust it. I measured the factory plugs I removed and they were between 0.028 and 0.029 inches.
Simply hand thread each plug until it's snug to prevent from cross threading. I was actually able to get it fairly close to the proper torque value by simply hand threading. If you have a knurled extension it makes it easier.
A trick for cylinder 4 is to place your ratchet at around the 8 o clock position to both loosen/tighten the plug so the high pressure fuel pump is not in the way.
*OPTIONAL : Torque Spark Plug to 12 Nm (106 in.lb or 8 ft.lb) depending on which torque wrench you use. I used my 1/4" In.lb torque wrench using a 1/4" - 3/8" adaptor to get mine to 106 in.lb. It did not take much force at all to reach that torque value.
STEP NINE :
Reinstall the 4x Ignition Coils and snug the 4x Ignition Coil Studs using a 8mm Socket. Reverse how you removed the cylinder 4 Ignition Coil by installing it at the 6 o' Clock position and twisting it counter clockwise.
*OPTIONAL : Apply a pea sized drop of Dielectric Grease on the inside of the Ignition Coil Boot and spread it around evenly using a pick (I used a Matco Straight Pick) and wipe the rim clean.
I say optional because some people use grease, some do not. Same thing with anti-seize.
STEP TEN :
Reposition the wiring harness and reattach the 3x plastic wire guides/retainers. Simply push down on them and they instantly bite on the Ignition Coil Studs.
Reattach the 4x Ignition Coil Connectors. Push on until you hear a 'click' and then use your finger to push the sliding lock tab forward.
STEP ELEVEN :
Once everything is reattached and properly tightened, crank your Ranger to see if a check engine light or any error message appears. You can always take a drive around the neighborhood as well prior to engine cover reattachment.
My Ranger roared to life and it seemed like it appreciated new plugs and the new engine air element I installed last weekend.
Reattach the EcoBoost Engine Cover if equipped by pushing down and reinstalling the 2x 10mm lock nuts. These just need to be hand tight.
That's it! Grab a cold one and enjoy a job well done! :sunglasses::thumbsup::beer:
The local dealer quoted me $130 just for installation (parts extra) so that is worth celebrating.
For the record it took me longer to write this write-up / take pictures than the actual job did. :LOL::beer:
To celebrate, I bought my first Snap-On ratchet with the “savings” from the spark plugs. Follow me for more financial advice. ? :crackup:
DRVMN
Saint Cloud, Minnesota
2021 Ford Ranger XLT FX4 Off Road
High School Mathematics Instructor
Thank You so much for creating this thread. It will be super helpful when I change my spark plugs!!! Very thorough and detailed - especially having the torque specs for the plugs.
Question - how long should the engine run so that it’s warm, but not hot? It will be in the 70’s when I do the work.
Thank You again - this is very much appreciated!!!
Trash Panda
Trash Panda
Cody
I drove 20 minutes round trip and it probably sat in the garage with the hood open for 20-30 minutes. The plugs were warm to the touch (not scalding or anything) so I think I got it just right.
Probably 10 minutes max if you just idle or drive around the neighborhood?
Josebd
2021 Ford ranger xlt
Road maintenance county
Ngk plugs dont need it
Trash Panda
Trash Panda
Cody
Nice job ? didn't opt for the anti seize eh?
Rumor has it NGK makes some Motorcraft plugs, I have a feeling these are since it’s stamped “Japan”.
NGK advises against anti-seize.
I’ll know in 60,000 miles if I should have. ?
Some small notes here:
It is a better practice to remove one connector at a time to avoid the possibility of crisscrossing the connector to another COP which can be easily done , depending on how they branch out of the harness.
And
Be careful with checking the gap on the new plugs - it does not take much to damage the tips on new age plugs, flatten it, they normally come pre gapped but in shipping they could be dropped and tighten the gap some
Other than that Great Write Up
Trash Panda
Trash Panda
Cody
And
100% agree.
I noticed my cylinder two COP connector had red tape around it (you can see it on the pictures) and that helped me not mix up cylinder two / three.
I used a feeler gauge instead of a classic gap tool; probably should add that in there. I just wanted to be 100% sure they were between the upper and lower limits prior to installation.
Conman50
Conrad
2019 Ford Ranger; 2014 Ford Fusion
Thank you so much for posting this! I'm nearing 50K and was planning on doing this soon.
One note I would add:
As a possible preventative against the water in the spark plug well that some people have experienced (me). I put a good amount of dielectric grease are the top of the spark plug well and on the rim of the coil boot to kind of make a grease dam or seal to help prevent water getting in. Not sure if it will work but only time will tell.
TJC
Very nice write up with excellent pictures. Even though I understood the process well, your write up will keep me honest. The gap and torque specs will keep me from having to dig for them as well. This write up is going in 2020 Ranger cheat sheet notebook, and in my 2020 Ranger eBook Library.
Well Done and Thanks!
One small correction, The low pressure fuel pump you reference is actually the high pressure fuel pump. The low pressure fuel pump is located in the gas tank.
Jason B
2021 XL STX SE 4x2
machinist
Nice and thorough. Good job on the write up.
Trash Panda
Trash Panda
Cody
55xxx miles, thanks for the writeup! debating when i'm replacing.
If you’re itching to wrench, now wouldn’t be a bad time.
Might as well add the DPFE sensor (the primary cause of our truck surging/bucking(there’s a 42 page thread on it)) to your project list if you haven’t already. Mine is on the way and another write-up to follow. :crackup:
@airline tech convinced me halfway through that thread I need a new one.
TJC
I have two sitting on the shelf in my garage just waiting for when needed. They are cheap now...might no be so in the future.
Trash Panda
Trash Panda
Cody
Even bought the special tool off Amazon, work smarter not harder.
