12v outlet in bed
crowsnest
San Luis Obispo county
2019 Ranger Super Cab 4WD
Is there a simple way to add 12v utility socket to truck bed? Can I tap into the trailer harness power supply?
Ranger X
Bruce
Marion, SC
2020 Iconic Silver Ranger Sport 4x4
Retired Fire Marshal
Does anyone know if this will work with a bed liner???
veedubtuner
Morgan
Tulsa, OK
2023 CG XLT Scab FX4 Ranger
VW Parts slinger
Spray or drop in?
I would think spray liners wouldn't be an issue, drop ins however probably will be. May have to get creative with a Dremel. I'm sure if you message Wolf haus they could clarify
Here
XLT
Spray or drop in?
I have a drop-in bed liner and they do not sit tight up against the bedside walls. I think the easiest way to get it to work is to use a hole saw to cut a large enough “porthole” in the liner where the plug is mounted to the bedside. Similar to the access portholes for the tie-downs.
There are structural grooves in the liner that are like to cause problems with fitment of the plug.
crowsnest
Thanks! My truck came with plastic bed liner that covers the mounting hole. Any idea about how far it is from tailgate?
It's right behind the rear wheel
Ranger X
Bruce
Marion, SC
