120v outlet
mtsoxfan
NEK VT
Has anyone used the 120v outlet for anything substantial? I am going to be working on my retirement property which has no power. I need to use a hammer drill to secure shed wall to foundation before I straighten it. Single slope, metal roof and sides. Thanks for any info.
It is limited to 150 watts - not a ton. All I've used it for is to plug in a charger for my cordless drill when I was doing some work on a rental house.
I'm almost positive a hammer drill would take more than 150 watts.
mtsoxfan
NEK VT
Isn't it 110v? I would guess a hammer drill is going to be over the 150w limit. Sounds like you need to invest in a cordless drill
Thanks, I have a cordless but I'm drilling into concrete, so hammer drill.
Augie81
The manual also says not to use it with an extension cord and I'm guessing you would need one for the job. But I think the concern there is using it to power more than one device. Not sure. Anyway, you might be better off renting a generator, throwing it in the bed and getting to work with your hammer drill.
JeffB
Kentucky
Muastang, Mazda 6
It is basically useless. Had hoped to use it for electric chain saw and weed eater... They won't work, but I can make a piece of toast.
Murphie
Lindale TX
Financial Auditor - Retired
I tried to use it once with an electric leaf blower - was going to clean out a storage unit, but it wouldn't work. Had to resort to using a broom. ?
Old NaCl
Greg
2019 XLT Ranger 2X4
Mechanical Designer
The plug is about 10 times to weak.
Either use cordless, rent a generator or purchase an inverter that can supply the power.
Reactions: EJH
dkirby
USA
'22 Lariat Tremor, '16 Focus RS, '10 Evo X
I bet you can't make toast either. Any electrical heating element is going to take a high current. Hair dryers are usually 1000-1500 Watts. A 2 slice toaster must be at least 500 Watts.
Bullet
MiddleMerica
Toaster would require more watts than the outlet can put out. So..... guess you're just having bread =o)
JesseS
Jesse
NorCal (Roseville)
