XLT vs Lariat gauge cluster
NHR
GA
Tundra
Very cool! Thanks for the info. I'm going to give it a other shot when I have a minute
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Ford ASSET Instructor - Program Director
Bummer. I tried out my XLT cluster today.
I'm wondering if I need to find a cluster from an XLT FX4
No, you need to program your cluster with the options your original cluster had with your FORScan.
If you reinstall your OEM cluster and save the As Built data and then reinstall the 'new' cluster you can then push the As Built data back into the new cluster.
NHR
GA
Tundra
Brilliant! Thank you for the tip
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Can't take credit for all the info. I'm a car guy for sure, but I'm new to FORScan and learning every day.
Hoping that the new RH switch pack is truly the fix for the inop station tuning steering wheel buttons.
LB357
Headed West
'19 Lightning Blue Ranger
Follow up on the ACC test, works like a charm again! So thank you to @NHR for getting me to go back out and dig through Forscan and now I've got all the functions of my original Lariat, minus controlling the radio with the upper right switch pack.
NHR
GA
Tundra
Well I finally got my cluster installed and ran my as built IPC in Forscan. Success!
The one thing I'm surprised by is I can't see my tire pressure anymore. Is that feature not available on the XLT? I figured it would be under Truck Info but the only screen there is Off Road
LB357
Headed West
Nice! It should be available, maybe just need to activate it in Forscan? I know mine was until I disabled it after getting new tires and wheels and forgetting to get sensors installed.
Living The Dream
It's there.
While I agree that it should be under Truck Info, it's actually under Driver Assist.
Select Driver Assist and it's down the menu a bit.
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Reviving an old thread for updated info
I CAN CONFIRM that if you purchase the correct RH switches SW-8207 and program/switch the SCCM with the other RH switch pack choice in FORScan, you can have an XLT cluster in a Lariat with the correctly functioning RH switch pack buttons (volume, mode, mute, phone, channel buttons, ect...)
If you don't swap in the correct XLT switches, only the volume buttons work for the radio controls with the XLT cluster.
daczone
2020 Ranger
Can you give me the coding I need to do when doing this swap? My cluster just arrived and my switch is on it's way via Tasca. Thank You
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
First thing, with FORScan, make a backup of your IPC's AsBuilt.
Then install the buttons and the new to you IPC
Push the backup into the new IPC.
Open the SCCM config up in FORScan and change the RH buttons to the other available choice - If I'm remembering correctly, there are only 2 choice for RH steering wheel switches.
Clear codes and that should be it
daczone
2020 Ranger
Thank you... Just waiting on my new button. Cluster arrived on Friday.
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Button install is pretty straight forward.
I found it was just as easy to pop the steering wheel off and work on the bench as it was to stand on your head to find all the little screws that retain the trim plate around the switches.
daczone
2020 Ranger
Well it looks like I got a bad cluster, It does nothing when plugged in and forscan cannot find IPC and lots of errors about lost communication. Argh!
Does forscan update your mileage?
AvalancheFX4
Joel
Los Angeles
2022 Avalanche grey Lariat Ranger w/ fx4 package
Keeping it real
Why pay for lariat features and pay again for XLT?? The lariat dash cluster is perfect, fits the truck interior well. The regular cluster looks like an economy car cluster.
