XLT vs Lariat gauge cluster
LB357
Headed West
'19 Lightning Blue Ranger
That's awesome! Can you tell us what happens with the right side steering wheel controls? Are they just dead now?
Nope, they still work. I actually changed the controls in Forscan to the non-Lariat switch pack thinking I needed to after swapping the clusters which made them quit working but after realizing that I changed the setting back to the Lariat pack and had volume control, prev/next, etc.
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Ford ASSET Instructor - Program Director
New guy here. I found this site through a Google search.
@LB357 could you elaborate what you did or didn't do or maybe what options you have that I might not have?
Installed an XLT cluster in our Ranger this weekend and it's working great except for the RH buttons to change stations. Volume works as well as all the other lower RH buttons. Wifey likes the dash but isn't too thrilled with the loss of the buttons to change radio stations.
I went into the SCCM and changed the steering wheel button setting with no luck - changed it back.
If it matters, I have a 2020 Lariat.
Thanks ahead of time for the assistance.
LB357
Headed West
Sure, sorry about the late reply on this. The physical swap itself if simple, it just requires popping off the vents to the left and right of the cluster and then lifting up the cover between the steering wheel and the cluster itself and removing the 4(?) screws holding it in place. Once the 4 screws are out you just have to pull the cluster towards you and disconnect the cable from the back. I did all of the with the truck off. Just reread your reply and realized you've already done the swap but since I've typed this out I'll leave it up for anyone else. I also realized after doing the swap I don't seem to be able to use the adaptive cruise control but normal cruise still works and the top right button pack to control the previous right screen no longer does anything but those were worth it to me as I much prefer the XL/XLT dash. Did you update your mileage on yours new cluster via Forscan?
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
Thanks for the reply.
I think I'm going to take the plunge and buy the other RH switch assembly.
There's only 2 different versions available and there's also only 2 listed in the SCCM so it makes sense to me to install the non-Lariat switch assembly and tell the SCCM that it has the non-Lariat switches.
If I change the RH switch setting in the SCCM but leave the Lariat switches in, I get an internal failure code for the switches in the SCCM so that's telling me that the resistance is different for each button press when you compare the 2 versions of switches. Steering wheel switches are on a voltage divider circuit and each button press changes the resistance 'signal' to the SCCM.
I have a call in to a friend that works at an OEM manufacturer/supplier to Ford - he's investigating the resistance values for me since they only have the contract for Broncos right now.
In answer to your question, I have not updated the mileage yet. Didn't want to until I get the switch issue sorted out. This is a deal breaker and low Wifey approval not having the switches working. I have all mileage documented - the new to me cluster has more mileage than ours does, so I'm waiting for our stock cluster to work its way up to the mileage on the XLT cluster.
Thanks again,
Dan-O
svgrdr
Elton
Maine
2021 Ford Ranger XLT
Hello all,
I'll soon be taking delivery of my new (to me) Ranger Lariat. After a lot of debate I jumped on a reasonably priced 2020 with the 501A package. The leather, B&O, and adaptive cruise were important features for me.
The one thing I'm not stoked about is the instrument cluster. I much prefer the basic XLT arrangement with analog tach/speedo and a center info screen.
Would it be feasible to swap my Lariat cluster for an XLT one? Is there any functionality I would lose?
I much prefer real guages and less screen as well, and I am very happy with my XLT
NHR
GA
Tundra
Did anyone else lose the adaptive cruise?
I bought a used XLT cluster and plan on swapping this weekend.
Main reason I got the XLT is the gauge set. The only thing I’m really missing is the lariat led headlights. But…. That’s what aftermarket is for along with this forum. It’s on the bucket list now
Same for me! I did not like the lariat cluster screen. i guess im old school but i prefer the analog gauges and the three split sections vs. the more modern. Also the lariat price tag had a factor for me as well lol. everything I wanted was on the xlt list with the mid package.
NHR
GA
Tundra
I'm running with an XLT dash cluster in my Lariat.
The cluster is plug and play, but...you loose the Nav, Media and Phone display. Worse, the upper right steering wheel switch pack also looses most functions.
The good news is you can swap In an XLT switch pack, make a single SCCM config change using Forscan and voila! it all works like an XLT.
I think with a lot more SCCM config changes, the Nav, Phone and media menus/displays and be enabled on the XLT cluster but I've not had the time to experiment.
Did you lose the adaptive cruise functionality like the other poster in this thread?
LB357
Headed West
Thanks again,
Dan-O
Do you have the part # for the other RH switch assembly? If not, I believe I've got it jotted down somewhere and can look as I was eventually planning to do the same. I plan to hop back into Forscan to see if there's anywhere I can look at messing with ACC settings to bring that back too.
LB357
Headed West
Correcting myself on a previous reply, I think I misunderstood what NHR had asked when originally asking about the switch packs. The upper right switch pack (arrow switches) does not work as is, being in the Lariat configuration still, and I have not yet swapped out for the other variant to test with Forscan changes. Wanted to clear that up for any future references.
5G Dan-O
Dan
Morrisville, NY
2020 Ranger
It has been confirmed that once the mid-level switch has been installed and changed in the SCCM to the correct option the RH switches will work.
https://www.ranger5g.com/forum/threads/lariat-to-xlt-instrument-cluster-swap.10788/post-340603
The part number for the switch is: SW-8207
So far Tasca had the best price but I have a friend that's investigating at dealer pricing.
https://www.tascaparts.com/oem-parts/ford-switch-assembly-control-sw8207
SOHK_Alumni
Win
Tampa
Glorified Mechanic
Mine is a "base" Lariat so no adaptive cruise, but I've been looking to add it.
NHR
GA
Tundra
Bummer. I tried out my XLT cluster today.
I have a Lariat FX4 with adaptive cruise.
After hooking up the new cluster I didn't get any warnings, but I lost some functions. The Terrain Management switch didn't display what mode I was in and my locking diff also didn't display any indication of activating. The cluster also didn't quite fit; I couldn't get the lower right hand hole and alignment pin to line up.
I didn't drive it at all and switched back to the stock Lariat cluster. I'm going to do some research in Forscan to see if I can enable those displays, otherwise I'm sticking with the Lariat cluster.
I'm wondering if I need to find a cluster from an XLT FX4
LB357
Headed West
Interesting, when I hit the Terrain Management button it cycles through and shows me on the center screen which modes I'm cycling through but my locking diff doesn't show up when I activate or deactivate it like you mentioned but I can hear it engaging and disengaging. I'll have to scroll through my Forscan settings today if I get the time to see what all is activated as I know I've played around in it after installing the cluster. When I purchased mine it didn't specify if it had the FX4 package or not, just that it was an XLT cluster.
LB357
Headed West
Had a chance to run out to the truck earlier than expected. Hopefully good news(?) @NHR, I hopped into Forscan and searched on "adaptive" and enabled three Adaptive Cruise Control settings which now shows a menu I didn't previously have when turning cruise on but I haven't yet had a chance to test if it works. I also searched and found where I could "enable" Electronic Locking Differential (E-Locker) which now successfully shows when it's locked or not. I tested if it shows while it's in and out of 4WD and it does show regardless if you're in 2WD/4WD. I could hear it engaging when hitting the button so that seems all good again. I triple checked the Terrain Modes again after making the change and they all show up as usual. The settings I believe that are related to that and that I have enabled are as follows:
Intelligent 4WD Gauge
Intelligent 4WD Gauge Mode Feature
Off Road Gauge
Off-road Screen
Selectable Drive Mode
They may not all pertain to it but it's what I have enabled to keep or add functionality for it. Hopefully I'll get to test out these new settings, especially the adaptive cruise again and see if that's all it took. The pictures attached don't show it in any specific order just verify that I have the locker showing, TC modes, and possible adaptive cruise settings again.
