ControlNode
- First Name
- John
- Joined
- Nov 29, 2021
- Threads
- 17
- Messages
- 1,732
- Reaction score
- 3,734
- Location
- Eastern NC
- Vehicle(s)
- 84 Civic "2000S"/16 Focus RS/21 Ranger XLT
- Occupation
- Computers
If you were to use the pin, keep a couple things in mind. As mentioned before, the pin could bend, more so if it's a solid one. You can get the pin with sleeved up size so you have a "pipe" on the pin instead of just the pin and the sleeve is more often more resistant to bending. Also, consider if the rope is coming out of the hitch at an angle. Are the edges there it could rub on going to damage it, do you need a protective sleeve on it there?Is a pin a replacement for a shackle? I was thinking about getting a shackle in the event I could help someone out of a ditch but realized I had a tow rope and a hitch pin.
I would go with the 2" hitch to shackle setup and only think of using the pin in the hitch like that for emergency type events when the hitch shackle is not on hand.
