Where do you put subwoofers
Philvarah
Phillip
Arvada, CO
2022 Ford Ranger XLT Splash
Sales
Thought I could put subwoofer under back seat ... But appears no clearance... Maybe attach to bed wall behind back seat... Or under passenger seat... Glove box...Or center console... Or WTF..
Not much room anywhere!
Jason B
2021 XL STX SE 4x2
machinist
I put a powered Kenwood under the driver seat. Feels good man! ?
Behind the rear seat. Plenty of room for one of those slim subs. Made a custom mount for installing it at the factory sub mount point.
I have for some time contemplated buying one of those slim sub-woofer systems. Are they worth it and do they produce a decent bass? I'm not looking for something that will shatter the windows or anything like that.
JoeDirt
TX
2021 Ford ranger xlt
I would say that my cheap MTX is just what I was looking for. Something to add some pop and lows that the 6.5s in the door can't produce. It won't shake the house or the car next to you. But for adding the missing low element in the audio it's perfect.
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
Philvarah
Philvarah
Phillip
Arvada, CO
Sales
Yes... After extensive research...not much room for an install...hope the 2024 allows for more behing the rear seat cargo space..... A sub box and a 10 or 12 in sub plus an amp and wiring kit takes up too much space ... So going with Cerwin Vega 12 in Slim Sub w/ amp combo that's only 13 in X 11 in and mounting on driver's side behind rear passenger seat.... direct power to battery...Will mount to allow air circulation to not overheat... And be mindful to not blow out sub by exceeding 70% max power.
Living The Dream
I have the Kenwood KSC-SW11 and it fits easily behind the rear seat.
The remote is in my armrest console.
It sounds very good.
Philvarah
Philvarah
Phillip
Arvada, CO
Sales
Going with same option on my 2022 Ranger...
JimmyH
Jimmy
TX
2023 Ford Ranger XLT Crewcab; 2020 Ford Escape SEL
I went with the Kicker Hideaway 11HS8. It fit behind the backseat with wiring ran behind the carpet. I tapped into the B-pillar wires for signal. Amp control and power wiring were ran along the driver's side floor. The remote gain knob is mounted with with sticky back tape under the steering wheel adjust lever where it is out of sight. Be sure to do the FORScan mod to flatten EQ. It does fill out the sound and is pretty nice for inside the cab. Just don't expect a super loud system like you would get from two true subs mounted in a box. My brother says it sounds better than his B&O subwoofer in his F-150.
